Injectors not firing 2019 Peugeot boxer
Paulky67
Unread post by Paulky67 »
Hi, does anyone know why my 2019 Peugeot boxer 2.0. injectors won't fire. I get the correct pressure at fuel rail and have tried new injectors. I also don't have any faults show up on diagnostic scanner.
x 1056
Re: Injectors not firing 2019 Peugeot boxer
Unread post by wheeler »
Can you see engine RPM on live data? Do you have Cam & Crank synchronisation? Is the ECU unlocked by the immobiliser?
What's the background of the fault?
Paulky67
Hi cam and crank sensors show no fault. I'm not sure about the immobiliser, how can I check this. It's not showing as a fault. problems started because water pump jammed. Replaced rockers, then injectors started playing up.
