207cc Crank but no start.
wurlycorner
x 271
Re: 207cc Crank but no start.
Unread post by wurlycorner »
Colin2206 wrote: 17 Jan 2025, 18:45 Not sure how I can reset/calibrate them, maybe just unplug them and crank.
There's no way to calibrate them, they either work or not.
By 'correlation' I mean: the ECU is looking for rotation at both crank and cam and it compares the two/looks to see they are rotating at the right speeds and it sees the 'notches' (e.g. at tdc) at the right timing together. If it doesn't match the comparison pattern it's expecting to see, they are out of correlation.
I should say, it's unlikely to be the cam sensor (far more likely to be the crank as that's what's flagged) but it is possible, so worth checking.
Iain
CX DTR T2 Safari (silver)
Colin2206
(Donor 2022)
x 19
Unread post by Colin2206 »
Well, a pretty fustrating few days.
Still got the intermittent crankshaft sensor fault. As per previous post, the sensor and harness check out ok but I thought I would replace the wiring harness connector.
Peugeot tell the part code is P6569HY but they nolonger supply it. I've searched ebay and google but no luck so far. Not keen on going to the scrappers for a part like this.
So does anyone know of a supplier for the connectors? Even something that can be modified to fit?
wurlycorner
x 271
Can you match it to one from a place like these?
https://auto-connectors.co.uk/collectio ... 6JTgjbjDcZ
https://www.connect-consumables.co.uk/p ... r-Kit-24pc
(that's a kit of many, but scroll down on that one and the individual connectors are shown below)
Iain
x 1056
Unread post by wheeler »
You got a picture of the connector?
Colin2206
(Donor 2022)
x 19
The receiving end on the sensor is 15 x 10mm approx., so not very big.
https://www.ebay.co.uk/itm/224195089241?
https://www.ebay.co.uk/itm/315902940825
Found these, which look about right but can't make the part nos. line up.
Colin2206
(Donor 2022)
x 19
Nos. on this connection are 672 597 PA68 CF26 (or similar, very small markings) and the marked BMW.
Can't find anything on Internet with these nos.
PaulC5
x 667
Unread post by PaulC5 »
PA68 is most likely the type of nylon/polyamide it is made from. Similarly often PA66 is on plastic parts.
ozvtr
x 244
Unread post by ozvtr »
Colin2206
(Donor 2022)
x 19
Hello
I believe the part you need is this:
https://auto-connectors.co.uk/products/ ... 80d9&_ss=r
I got above this morning and it fits fine. Different coloured wiring harness though. And you guessed it, it didn't make a blind bit of difference. The P0339 code wouldn't delete. It is the only code on the Reader.
I've run out of ideas. Tomorrow, I'll re-check everything I've done, clean all the connections etc.
PaulC5
x 667
I think reading above you have not done anything with the cam shaft sensors. In this topic the fault turned out to be a cam shaft sensor viewtopic.php?t=58695 It also notes the PSA wording for P0339 does not mention crank shaft sensor but
is P0339: 'Intermittent fault, Engine speed signal: Incorrect signal'
If you post your vin admin might look up P0339 against your car.
We had one of the 2 cam shaft sensors fail on a 2010 petrol C3. Checking with a meter one of them gave different resistances across the pins but both were the same part number from what I can remember and a new one was the fix. I can not remember the fault code but it put it in limp mode and still ran.
Colin2206
(Donor 2022)
x 19
Vin. N0. VF3**************[VIN obfuscated, can be read by forum staff]
I'll check the cam sensors over the next couple of days.
Thanks for the help.
Colin2206
(Donor 2022)
x 19
Had a free hour this morning, so removed the cam sensors and checked the harness. Supply, signal and earth all appear to be ok (12v, 5v and continuity).
When I check the pins on the sensors I get 2.6-2.9 Mohms on one and 5 Mohms on the other sensor. I recall changing these out a few years ago. Not sure what ohms it should be. I'll check the Internet when I get back as well as re-running the test. A couple of cam sensors don't cost much.
wurlycorner
x 271
Glad you've checked the cam sensors now.
There shouldn't be that much variation in resistance between the two, for sure.
Even without knowing what the correct spec is, that's quite a mismatch and suggests at least one is faulty.
Try and make sure you get good quality replacement sensors (not generic cheap crap) and I suggest measuring both the new ones for comparison, before fitting.
Iain
ozvtr
x 244
Colin2206 wrote: 30 Jan 2025, 10:29 When I check the pins on the sensors I get 2.6-2.9 Mohms on one and 5 Mohms on the other sensor. I recall changing these out a few years ago. Not sure what ohms it should be.
If it's 3 wires and is supplied power and ground, then it's going to be an active device. That is; it will have semiconductors in it, so doing resistance checks will reveal nothing.
It's most likely a Hall effect device. A passive device would be an inductive pick up and would consist of a single loop of wire requiring only 2 contacts.
Colin2206
(Donor 2022)
x 19
Well, got two camshaft sensors and after a bit of work got them fitted; as usual engine threw over no bother. Tried to delete error code but it remained stubbornly there. However, I have two code reader apps on the 'phone and always try both as sometimes one will present info the other doesn't. So second app deleted code. Tried again, still nothing after several long cranks. Just about to 'phone the scrap yard, gave it one last try and away it went!
So spent most of the last two days putting everything back together, tidying up wirning harness connectors etc, and everything still looks good. Still need to take it for a road test and will do that in a couple of days.
The camshaft sensors seems to have been the final thing but I'm not convinced it was the only thing. If you recall, originally there was no error code, just the engine turning but not firing. Although there was power to the plugs and injectors, nothing fired. So that lead me to checking the ECU and finding the bad earth from the fusebox/relay, only after that was repaired did the error code appear.
So thanks you all for taking the time to read my posts and reply. Your advice kept me going and while a professional would have got there quicker, you got me there in the end.
