CITROEN C4 2012 Mirror Folding Electrical Diagram
KOBIKA24
Unread post by KOBIKA24 »
Hi friends, I need help
I have a Citroen C4 2012
And I have a problem with the right mirror. It doesn't fold and there is also a problem with the external temperature sensor.
The left mirror folds when I press the switch in the door.
The right side doesn't. The right mirror, right, down, up, does work
I took the door apart to check the connector. Everything is fine. I give power directly to the place where the mirror folds.
The scanner also shows a problem with it
No command comes at all
Help with the diagram and help with how to start checking from the BSI because I have no idea at all about electricity
Which connector to take apart from the BSI and start checking?
I need a full diagram with colors and also the switch in the door, how do I give it and where
