2014 CITROEN C4 PICASSO HEATER BLOWER ISSUES
TwoSixOne
Unread post by TwoSixOne »
Dear All,
I have an issue which appears to be relatively common here.
My VIN is VF7**************[VIN obfuscated, can be read by forum staff].
The blower motor cut out the other day and does not work at all. It fired up again this morning only to stop shortly after.
It seems to be one of the following issues:
1) Motor
2) Resistor
3) Relay
4) Water ingress
Has anyone had anything similar to this? I am wondering where the relays are on the 2014 C4 Picasso...
Kind regards,
Pete
TwoSixOne
Re: 2014 CITROEN C4 PICASSO HEATER BLOWER ISSUES
I think I’ve located the relay in the fuse box by the battery… it’s the green one… marked G CARTIER 12V 35A 03531… part number is 6547TX from another post so ordered it and will see how it goes… after this I will have to try the resistor… fan is still intermittent and was on again tonight before knocking itself off.
apcs41
Unread post by apcs41 »
I took am having some issues with my blower
What makes you think relay? Have you checked forr power going in to the blower resistor? Have you checked voltage at the blower motor?
