I know this has been covered before but i cant find a post thats the same.
My odometer works fine BUT the speedo goes upto 50 and stays there, or if it decides zooms back down again. It never goes above 50.
Any ideas as to what is the culprit here, thanks?
Xantia Speedo
JohnT
- x 1238
druist
Pete, do you mean the actual dial or the trnasducer? Is the unit attached to the back of the dial i see in the dashboard or the part on the gearbox?
is it just coincidence the rev counter has gone too. Neither worked since i have had the car - just the odometer.
Does the 1995 model have a transducer or just cable and worm drive?
JohnT
