Citroën c4 picasso automatic gearbox fault
Kelly84
Unread post by Kelly84 »
Hi, I have a citroen C4 picasso automatic which drives absolutely fine except for occasionally it cuts out when driving and it comes up with gearbox fault on the dash. It usually starts straight back up again after a few seconds/minutes and then goes again fine. Is this going to be an expensive job to fix? Will it need a new gearbox put in or will it be a simple problem to resolve? Thanks
x 6957
Re: Citroën c4 picasso automatic gearbox fault
Depends if you have a proper automatic or the piloted manual gearbox version. Pop your VIN up if unsure and I'll confirm it, before we go any further.
Kelly84
Sorry for.the late reply, the vin is VF7**************[VIN obfuscated, can be read by forum staff]
Reason: Masked vin
Mr_Flush
Unread post by Mr_Flush »
Hi, please can anyone help!! I have this very same problem.. did it get resolved?
x 1460
Unread post by xantia_v6 »
We need to know your VIN to determine which type of automatic transmission is fitted.
Any diagnostic fault codes would also help.
Mr_Flush
Citroen Dispatch 2021 - Auto Gearbox
Codes:
U1209:81
U1109:87
P00BA:21
P0090:77
P0087:77
P2291:26
Thanks for the quick reply
Dom
x 6957
This is an AMN8 Auto gearbox, so can't help with this one personally, but I know that U120981 is a comms fault with the Automatic Gearbox ECU (Data Invalid), so is likely to be a fault with the Intersystems CAN / harness or the gearbox ECU.
You also have 2 outstanding after-sales campaigns that have not been dealt with, so I assume you don't have it dealer-serviced...
I suggest you call them and book it in, work will be free, but you never know, some of these issues may be related, considering one of these relates to an engine harness. Just quote your VIN / Reg and the reference codes below:
HYS - Engine software (Jan 2022)
HUS - Electrical harness (Sept 2021)
