Citroen Relay/Jumper 2015 Alarm Wiring request
Pistapasta
Unread post by Pistapasta »
Hi All.
I am trying to connect a new Jablotron CA2103 can-bus alarm to my Jumper.
Everything is working fine (tnx to Can-Bus) but, i have a problem with Injection scheme find here: viewtopic.php?p=745793#p745793
Expecially for BF01 where some conductor seems non in the correct position (related to 32V MR connector, IDK if NR connector is correct or not, i've been stopped before).
My idea is to interrupt pump relay coil (low Ampere) or interrupt Starter fuse by an auxilliary relay for locking function.
Pls help me with a correct wiring of injection scheme.
VIN : VF7**************[VIN obfuscated, can be read by forum staff]
x 6955
Re: Citroen Relay/Jumper 2015 Alarm Wiring request
Your vehicle is actually only just a 2014 model not 2015 (built on 16th Jan 2014), so likely 2013/14 spec.
Here you are:
With the exception of the wiring codes, most of the component codes are indexed here:
PSA Electrical Diagrams - Wiring & Symbols Codes Index
Pistapasta
Whoa!
Thank you to your quick reply.
I think it's a vehicle based on 2014 because it's a Camper Van (they need time to assembly that). I've not a lot of information about this vehicle, it was imported from Germany to Italy and i have all manuals in German language.
x 1044
Unread post by wheeler »
If the system can only cut one circuit for immobilisation dont waste it on the starter circuit, its way too easily bypassed.
You could Interrupt the wiring for the inertia switch (component 1203). Starter cut is ok if its a secondary cut.
Pistapasta
wheeler wrote: 30 Dec 2024, 14:05 If the system can only cut one circuit for immobilisation dont waste it on the starter circuit, its way too easily bypassed.
Ok! I think this is the best solution, also because an auxilliary relay with 50/100A switch its a little bit complex to hide.
Pistapasta
Hello all,
Another question about this wiring request.
I've bought an optional for the Alarm system (the 2 scheme below) to use D C B outputs.
In that scheme there are a wiring about direction indicators and i want to know if i can use that scheme in my vehicle, and, if can have the wiring scheme of that zone for the VIN indicated in first post.
Someone chan help me, i think the first img is the right img for me.
x 1044
There are no indicator wiring on the diagrams above.
Normally on CAN alarm systems they dont need separate direction indicator wiring as it operates the indicators via the CAN.
Is this a tilt sensor? you could try wiring it up without & see if it still works?
Pistapasta
It's an option i can have with this accessory where i can start indicator lights by remote command and i can check the number of flash lamp.
Tilt sensor was connected in the mcu of the alarm system and, yes the system comunicate via CanBus with vehicle.
I've bought this device only for B C D auxiliary outputs (three GND with maximum 200mA outputs) and I want to know cable wiring before i discover an eventually problem.
Here the manual. I think to use option 235 or 435.
