Dear Forum Users,
I have DS5 2016 model 2.0 BlueHdi diesel 180 HP automatic car.
I need your advise regarding my higher pressure problem on expansion tank. Maybe I top up 750ml coolant every day due to expansion tank higher pressure issue.
1. There is no overheating issue and 90 degrees settling always when I drive.
2. Heating fans works well.
3. Sometime radiator is hot sometimes cold.
4. AC fans works well.
So far replaced bellows.
1. Expansion tank and cap replaced.
2. Air bleeding done.
3. Steel seal applied.
4. Cam belt and water pump kit replaced today.
But still I have same issue.
Is it possible radiator blockage or flashing issue ?
Or thermostat issue ?
Or head gasket issue ?
Please can you advise action plan if you had experience before?
Expansion Tank Higher Pressure Problem
- x 1486
Re: Expansion Tank Higher Pressure Problem
If it's not overheating, but the tank is over pressuring and blowing out coolant, then odds on the head gasket is gone. Does it pressurise quickly from cold (i.e. before it gets hot) / does it retain pressure overnight?
andyandjulie
- x 19
I'm with Richard on this one. I had same thing happen on a 240Z back in the day. My brother and I did it on a Sunday afternoon but cars were much simpler then.. It sounds like the gasket has failed between a waterway and a cylinder. An exhaust gas analyser wafted over the expansion tank might confirm. Hope I'm wrong.
Onlinemyglaren
- x 5673
There are kits available for detecting exhaust gas in the coolant, one here from Amazon.
May be cheaper elsewhere.
OnlineStickyfinger
- x 2000
This....they work very well
Muir
- x 13
If it ingests 700+ ml of coolant per day you should be able to see and smell by the exhaust - does the exhaust smoke perpetually or does it smell sweet?
Is there any black gunk in the expansion tank?
Can you confirm it's leaving by the expansion tank, any residue/dipple near it?
How did you comfirm the coolant system is overpressurized, just curious?
Might be worth dropping the lower plastic engine guard and look for coolant residue.
I honestly think it's much too early to target the headgasket, could be a simple leak.
OnlineStickyfinger
- x 2000
Or the gearbox is getting it via the box oil cooler (if it has one)....Muir wrote: 25 Dec 2024, 18:29 If it ingests 700+ ml of coolant per day you should be able to see and smell by the exhaust - does the exhaust smoke perpetually or does it smell sweet?
Can you confirm............................
Muir
- x 13
If it's the DW10FC engine yeah it has a small trans cooler on the gearbox.
Though I reckon the box would have seized already if it had that much coolant in it
mariusmight
- New User
What if it retains pressure over night? I really can't figure this out. I've got more of the same problem. Lots of pressure when running but also shortly after shouting it down. It goes on and on for a couple minutes maybe and you can hear the pops and bangs inside the expansion thank even tho the coolant is not even that hot, most of the time not even close to 90 degrees. I can even here the coolant rushing trough the coolant hoses, by time to time. I suspect the water pump, as the heater core also not warming up at all, no matter how much I've tried to bleed the system. Maybe it creates very hot spots? Maybe could be having something to do with the thermostat too? The CO2 test not too accurate as the blue-ish thing doesn't really change colour too much - I might need to order another brand maybe. If the head gasket would be at fault, wouldn't be normal for coulant to leak in the combustion chamber over night, and actually loose over night some of the pressure accumulated? When I removed the coolant cap in the morning, it erupted again like a vulvano, even tho engine was freezing cold by 0 degrees outside. No white smoke, no coolant in the oil, no oil in the coolant. Not overheating, actually barely warms up, and then stay at 90° most of the time...RichardW wrote: 11 Dec 2024, 07:38 If it's not overheating, but the tank is over pressuring and blowing out coolant, then odds on the head gasket is gone. Does it pressurise quickly from cold (i.e. before it gets hot) / does it retain pressure overnight?
