Meeting arrangements
Michel
Re: Meeting arrangements
Unread post by Michel »
If I'm not working that day, I'll be there. I'll check when I get home in a couple of days as I'm up North and purposefully left anything with any access to work and rotas at home.
Zelandeth
x 1605
Unread post by Zelandeth »
Have marked it down in the diary, so hopefully Jim won't need to poke me at the last minute to remind me this is happening for a change!
Current fleet:
x 8407
Zelandeth wrote: 08 Nov 2024, 20:04 Have marked it down in the diary, so hopefully Jim won't need to poke me at the last minute to remind me this is happening for a change!
Excellent Zel :) Delighted you'll be able to join the fun again!
x 1072
Unread post by Rp0thejester »
Are dogs welcome at that establishment? He's so soft and ANTI aggressive he walks pass cats like their a gate post and even welcomes some with a wagging tail.
x 8124
Not inside the eating room where we were. Ok in the garden I believe but don't know for sure.
x 1072
Well that's good to know, some establishments have a divided area for animals like the old smoking area, which was like having a peeing section in a swimming pool...
Rhothgar
(Donor 2026)
x 221
Unread post by Rhothgar »
Bloody Southerners! Get yer rear ends up this way one time somewhere within an hour of Snotta inga ham. An hour by Viking longboat, that is.
Michel
I can't make this one as I'm working next Tuesday :-(
x 8407
Do join us Roger and then you could collect your subframe on the way before it gets fitted to the big Xantia in the sky 😉
x 1072
I can most likely join on that day. I don't mind if it gets moved further north but I'm not sitting opposite James, his brain completely fries mine!! And with talks of printers and keyboards I request the closest seat to the door!!!!!!
x 1072
So maybe Roger could meet you and Zel Jim and get chauffeured, 2 birds 1 stone.
x 8407
Rp0thejester wrote: 16 Nov 2024, 00:22 So maybe Roger could meet you and Zel Jim and get chauffeured, 2 birds 1 stone.
Yes, and give a subframe a ride too ;)
Michel
I may be able to make it now, I'll just turn up and have a natter and a bowl of chips if I manage it.
x 8407
Michel wrote: 16 Nov 2024, 15:29 I may be able to make it now, I'll just turn up and have a natter and a bowl of chips if I manage it.
That'll be brilliant Mike :D As always, it'll be great to see you :D
Rhothgar
(Donor 2026)
x 221
Extremely unlikely I will be able to make it Jim.
I think that subframe should die. I only need the mounts out of it anyway!!!!
