x 6945
Part (6) Inlet Resonator Support, part: 9676891780, £16.64
(71) Screw with washer, part: 6922C7, £2.53
Skull
(Donor 2026)
x 381
Unread post by Skull »
VIN VF7**************[VIN obfuscated, can be read by forum staff]
AX lower radiator coolant hose - Please, no rush
Driveshaft rubbed coolant hose at some time
Gary
x 6945
Unfortunately the car is too old for the exact specifications to be carried over onto the new database, so it is making no distinction based on VIN. I'm assuming you have a Monopoint Injection system, as the others are for diesels, so these are what they are showing:
(1) Radiator Water Inlet Hose Diam Int. 32X28, (Without Air Conditioning) part: 96022712, £85.13
(2) Radiator Outlet Hose, part: 96083171 (NFP)
(3) Heater Water Pipe, part: 6464L3 (NFP)
Skull
(Donor 2026)
x 381
Thanks Marc that (1) looks the part....
Gary
jsich
Re: CitroenRe: Important Information concerning access to PSA parts DS Automobiles and Peugeot Official Part Number Requ
Unread post by jsich »
Hi Marc,
Is it possible to get the part numbers for front brake disk dust covers / shields for 508sw 2013 1.6hdi
Vin: VF3**************[VIN obfuscated, can be read by forum staff]
Thank you
x 6945
Here you go:
(12) Front Brake Disk Protectors
Left Part: 4209G7, £38.08
Right Part: 4209G8, £38.08
(72) Screw with Washer, part: 6923C6 (sold in pack of 6), £2.38 ea.
jsich
Thank you
stickery74
Unread post by stickery74 »
Hi could you supply me with a part number for an offside rear suspension unit for my 07 plate C5 estate. Vin number is VF7**************[VIN obfuscated, can be read by forum staff].
Also advice on where to get this part would be appreciated. Thank you.
x 6945
Sphere, Strut or Pipes?
(1) Hydraulic Struts (no longer available from Citroen):
Left, part: 527272 (NFP)
Right, part: 527271 (NFP)
(3) Suspension Sphere, rear Left or Right Corner:
Original part: 11638046280, £150.73
Cheaper part: 1638377480, £73.02
Available from your Citroen dealer apart from the Struts.
stickery74
Strut
x 6945
Ok, please see above, these are no longer available from Citroen.
cs101
x 6
Unread post by cs101 »
Hi, Marc,
Please which is the recommended engine oil for my van , 2018 model Peugeot Expert?
x 6945
You need 0W30 that meets PSA specification B71 2312.
Huskyxantia
x 909
Unread post by Huskyxantia »
Hi Marc , im going round in circles here ,Is 0532L2 a part number for a flywheel for a C3 Picasso , i keep finding c4 ones nearly every search i do.
Vin VF7**************[VIN obfuscated, can be read by forum staff]
Is there a part number for solid type aswell as dual mass. Thanks.
:-D
x 6945
(10) Dual Mass Flywheel, Diam 291 131 DTS OEM Valeo (Embray), part: 0532T2. £697.39.
Citroen do not provide Solid Flywheels as alternatives where DMFs are fitted as they don't do the job they were designed for and will put additional torsional stress on other transmission components.
