x 8365
In between a lot of baking (bread, scones and flapjacks 😋), running Bury Field for a parkrun check, getting the parkrun kit together for the weekend and cleaning the house I got a good bit done on Bluebell :D
First up, removing the air intake and air box I found this horribly perished vacuum pipe feeding the summer/winter flap on the air intake.
That pipe is only about 18 months old - eBay rubbish :evil:
The air filter element, still the same one from the days before Bluebell was rescued, is now looking a bit past its best so will be replaced... I have one in stock and a couple more on order.
Then, with access gained, I set about loosening the inner track rod end locknuts... They were outrageously tight and I needed to make up a bit of a 'special' breaker bar to use with the crowfoot socket...
The inner track rod ends have, quite logically, left-hand threads. It's obvious from the threads if you know what you are looking at but worryingly, not mentioned in the BoL... I'm sure this has caught out a few people before now...
Then, with those loose, I undid the track rod end through-bolts from the rack yoke...
And out they came :)
The inner track rod ends would not rotate freely in their track rods so I fully removed the whole RH track rod to work on it on the bench. It soon freed up :)
In doing this, I found the after-market new track rod end I fitted for the MoT had an incorrect taper profile :shock: It was hellishly hard to separate it from the strut steering arm.
As the old joint was fine and just needed a new boot, I swapped the boot ;) All now good with the old joint back in service...
That an after-market item could be incorrectly profiled is worrying. This was not an Autodoc one. I shall now check my Autodoc spares...
This is the inner track rod end up close:
The rubber looks perished to the casual eye but is not. It just superficial and there's absolutely no play or what I'd consider excessive 'give' in the joint at all. It can do a further turn in what is after all, a very lightly used car.
Strawberry's I know do so she, being the more heavily used AX, will get new inner joints.
I now have to pop the LH track rod out to free off the inner track rod end thread and give the inner track rod end rubber parts close inspection.
x 8365
Rp0thejester wrote: 01 Nov 2024, 17:17He's not known to be dangerous, just hang a picture of an AX from a stick and he'll follow you like a donkey. I'm sure the face looks familiar just can't think why :-k
:rofl2: :rofl2: :rofl2: That's really made me giggle Ryan :-D
I do have a few AX models and here's one of them :)
Posing in front of my laptop... The post being displayed is very relevant ;)
x 8365
Only a little done on Bluebell today, due to otehr activities..
When I first had her, there was a fair bit of debris in her fuel tank and it took several changes of fuel filter before the fuel ran clear.
I rebuilt the carb in the early days of my ownership as it was in a terrible state...
The last couple of time I have driven her, I've noticed a bit of a stumble if given a good dose of throttle, suggesting the accellerator pump was not quite the full shilling...
I removed the top of the carb. and this was what was sitting in the bottom of the float chamber :shock:
It's amazing what got past the fuel filters in two years!
I found a bit of muck in the accelerator pump intake valve - a ball bearing in a tube - and after cleaning it, all seems good although the proof of the pudding will be in a road test which, with the steering all in bits, was not really advisable!
I note the carb. is quite worn on the butterfly spindle and will be on the lookout for another one... If push comes to shove, I'm sure I can rebush the shaft...
x 1067
Unread post by Rp0thejester »
What were the odds of that after Mikes steering column ball bearing story!?
Zelandeth
x 1593
Unread post by Zelandeth »
Seeing the mention of eBay vacuum hose, just going to do the obligatory plug I do every time I see someone either mentioning disintegrating hoses or mentioning they've fitted something bought from most motor factors (which is generally as bad as eBay/Amazon these days).
https://www.glencoeltd.co.uk/cohline-fuel-vacuum-hose/
That's the only place I buy fuel/vacuum lines from these days, and have done for the last year or two. Especially sinc Motor Parts Direct down in Bletchley, a supposed Gates Professional stockist denied that the Gates Barricade line of hoses even existed. I just gave up at that point and went with a company whose products are pricey, but who have a very, very good reputation and who apparently do very much care to keep it that way, so get their stocks directly from Cohline rather than from some random wholesaler in China.
Current fleet:
x 1067
Did you speak so it auto typed? Reads exactly how you speak Zel.
x 8365
Zelandeth wrote: 02 Nov 2024, 23:10 Seeing the mention of eBay vacuum hose, just going to do the obligatory plug I do every time I see someone either mentioning disintegrating hoses or mentioning they've fitted something bought from most motor factors (which is generally as bad as eBay/Amazon these days).
I found another one yesterday Zel, and I'm getting really fed up with the quality of a lot of stuff these days... Especially that originating in Asia :twisted:
I sourced a new rectifier for Alasdair's battery charger and I didn't notice it was from China. Took ages to arrive and was totally unsuitable for the job. It did not match the description and I threw it away; it was shoddy and unlikely to have functioned...
A sad fact is some of the OE 35 year old rubber stuff on the car is still good...
Rp0thejester wrote: 02 Nov 2024, 17:44 What were the odds of that after Mikes steering column ball bearing story!?
In this case Ryan, the ball bearing is a functional part of the one-way valve... A sliver of something stopped it seating...
Rp0thejester wrote: 02 Nov 2024, 23:14 Did you speak so it auto typed? Reads exactly how you speak Zel.
Saves a lot of typing ;)
x 8365
A bad hair day for me today - I appear to have grown a mohican :lol:
It's actually the top of a tree in the background...
The picture was taken during a very social club run. I'm the one on the left ;)
Afterwards we repaired to a Waitrose café for coffee. Surprised such a high-lass establishment lets a crowd of lycra-clad sweaty individuals in, but then, if you look past our appearance and focus on how much we drink and eat, it can't be bad for their profits!
x 8086
Quite scary how the angle of your head in that picture actually parallels the adjacent one in your profile Jim!! :-D
x 8365
mickthemaverick wrote: 04 Nov 2024, 17:27 Quite scary how the angle of your head in that picture actually parallels the adjacent one in your profile Jim!! :-D
Hey yes, now you mention it, it does! I'd not noticed it... My normal pose and demonstrating just how unbalanced I am :lol:
x 1067
We can see your unbalanced from your laptop photo, head at the same angle....
x 1067
I want to apologise to you Jim, I didn't realise that after my post that you would put a Hex on Letchworth and plunge us into darkness for 30minutes!!!!!..... I know you've calmed down now as power is back on. ( We honestly had a power cut for 30 minutes.)
x 1067
Once again I apologise as power is off again....
x 8365
Rp0thejester wrote: 04 Nov 2024, 20:27 I want to apologise to you Jim, I didn't realise that after my post that you would put a Hex on Letchworth and plunge us into darkness for 30minutes!!!!!..... I know you've calmed down now as power is back on. ( We honestly had a power cut for 30 minutes.)
:lol: :lol: My powers range far and wide Ryan :wink: :twisted: :-D
Being serious for a moment, I really am unbalanced left to right and during my diagnosis back along it was a big concern; It stems from brain damage that came along with my ME although initially it was thought I'd suffered a stroke, especially as I'm a little numb all down one side and lack coordination and balance. Running and cycling helps this aspect a lot.
MRI scans showed lesions on my brain, likely as a result of the viral infection that initially kicked off the ME.
So, I can honestly and truthfully state I'm not right in the head :lol:
x 2337
Unread post by MattBLancs »
CitroJim wrote: 05 Nov 2024, 05:05 So, I can honestly and truthfully state I'm not right in the head :lol:
As my late grandad used to always say when asked "are you alright?"
Spoiler: show
yes, but just down one side!
CitroJim wrote: 04 Nov 2024, 17:23 I'm the one on the left ;)
My left or your left!? :rofl2:
