Injectors misbehaving but trying to understand the numbers
Rhothgar
(Donor 2026)
x 221
Re: Injectors misbehaving but trying to understand the numbers
Unread post by Rhothgar »
MattBLancs wrote: 31 Oct 2024, 06:57
darbuck wrote: 31 Oct 2024, 06:52 I think it's becoming OCD with that car to be honest with you.
"We choose to go to the moon" type approach. I'm the same. I want to be able to fix it because I want to be able to fix it. All as daft as one another! :)
Agreed. I suppose I could be described as the loopiest repairing my ECU instead of buying one on Ebay for £16 delivered. 🤣
darbuck
x 291
Unread post by darbuck »
Yeah I think that's what it is. I'll update you with pictures over the coming days.
Darren
darbuck
x 291
Rhothgar wrote: 31 Oct 2024, 07:26
🤣 We just love the hardship.
Darren
darbuck
x 291
Hi lads cleaned the oil off the back of the engine. All good I think. It looks like the turbo was full of oil though, hopefully not so much that it ran on it. No smell of burnt oil off it though. I'll do a leak down test on it tomorrow and pull the old engine if it passes I have the old engine disconnected anyway.
Darren
KennyW
x 165
Unread post by KennyW »
Good luck Darren,
Kenny
C3 1.4 petrol (SWMBO)
darbuck
x 291
Thanks Kenny, I'm hoping to have it running by Sunday evening..
Darren
x 2341
Unread post by MattBLancs »
KennyW wrote: 01 Nov 2024, 19:39 Good luck Darren,
Kenny
Ditto!
Hope the weather is kind for you :)
darbuck
x 291
Thanks Matt. Well it's supposed to be dry until Tuesday so I guess we'll see. I should be able to get the swap done tomorrow and then just connect everything up tomorrow and Sunday 🤞
Darren
darbuck
x 291
Hi all, I'm revising my timeline there's too much to get done in one weekend I would imagine next week in the evenings and the weekend I should have it up and running.engine is disconnected but still have to drain gear oil and remove driveshafts to remove them as a unit. I find it easier.Smoke tested the new engine and all looks good no valve leaks. A small bit of leakage past the rings but this is normal as they never really seal 100%. I didn't detect any smoke coming from the coolant system which should mean the head gasket is good too.
Darren
darbuck
x 291
Ok so engine and gearbox out. removed the loom but haven't swapped it onto the donor engine yet. There are a few differences between them. The donor has a double doseur valve, mine is a single I don't know what the difference is with these. I assume the double is from the earlier 136bhp engine input welcome.. Unfortunately the replacement I discovered when I removed the doseur the plenum is clogged with carbon.i'm going to install as is to see if it runs first, and if it does I will swap my one over. I got the oil cooler and alternator swapped over so a start. It got very damp so decided to leave it around 16':30 as it was getting dark anyway. It was 17:30 again I finished cleaning up. The loom needs tidying as well so will do it tomorrow in the comfort of my home office. I don't want to change much as I want to make sure I'm not introducing problems unknowingly. Sorry no pictures yet I got carried away with getting a done.
Darren
KennyW
x 165
Easy to understand the excitement, new engine etc.
re the double doseur valve. On my 163hp it was only a single even though a double was fitted to the car. It was blocked off when the car was built in the factory.
Possibly yours is the same.
Kenny
darbuck
x 291
Maybe so. I don't think it will make any difference if I swap them.. I just get engrossed in doing these kind of things and forget about the outside world.
Darren
darbuck
x 291
Ok so I have transferred the egr, turbo, and pre-cat and oil cooler across to the replacement engine. I have also tidied up the loom and it is now ready to go on to the engine. I need to install the vacuum hoses and solenoid valves and fuel and vacuum pump and injectors..I was hoping I wouldn't have to take the intake plenum off but I can't install the loom without removing it. I still have to do the timing belt and water pump,clutch and flywheel. I still haven't removed the gearbox so a lot of work yet to go.
Edit
I then have to put the front back on to the car.Just going to relax for the rest of the evening.
Darren
KennyW
x 165
Well done Darren,
Slow put sure progress, also it will allow you thinking time away from the car when you stop.
Kenny
darbuck
x 291
Thanks Kenny, Yeah slow and steady making sure everything is as good as I can make it. I think I am going to over shoot my new timeline as well. I bought parts but they are only dispatched from Germany I think today, so will probably be next week before they are here plenty to be getting on with though. A bit of time to think is a good thing. I bought them over there to save a few cuid and they are genuine parts so guaranteed fit.
Darren
