- x 6960
I've responded in the original thread Alasdair, as he'll need to upgrade his membership for this service.
GORAX
- x 14
https://www.bandel-online.de/neue-artik ... uro-6.html
Hi all!
is this the right spare part for my car? To change my FAP/DPF
Hi all!
GOOGLE TRANSLATE
- x 6960
(16) New Citroen Genuine Particle Filter , part: 1609929980, £1735.56
Standard Exchange Particle Filter, part: 1610146080, £727.33
508c5
- x 4
Hi MarcGiveMeABreak wrote: 27 Oct 2024, 11:49
(1) Engine Mounting Bracket, part: 9673585680, £149.63
(2) Engine Mounting Bracket, part: 9820296280, £194.57
(4) Engine Mounting Bracket Left, part: 1610975280, £97.32
(6) Anti Torque Link, part: 9808838680, £103.87
(8) Engine Mounting Bracket Left, part: 9673773080, £99.74
(10) Engine Flexible Mounting Left, part: 9673768480 , £192.62
Can you share the "protocol" for the replacement of the transmission mount on this one?
Thx
- x 6960
Sorry, I don't have that.
dylan26__
- x 22
Could I please have the part number for the anti roll bar on VF7**************[VIN obfuscated, can be read by forum staff] . Somehow manage to bend mine
Thank you:)
Thank you:)
- x 6960
(1) Front ARB, part: 5084P3, £390.25
(4) ARB Rod, Part: 1646621980, £72.35
renel
Hi, my vin is: VF7**************[VIN obfuscated, can be read by forum staff], GC4P 1.6HDI EGS.
On this car, with this trim, the rear gate window kan be opened and therefore the wipermotor is fitted to the gate and a wiperconsole is fitted to the window and they are connected by a pin when the window is closed. Sorry, this is the only way that I can describe the part I am looking for...the p/n of the console itself is what I need, the bush is worn so water gets inside through the worn bush and worn o-ring.
René
René
- x 6960
Hi René
Have a look at the rear washer diagram below, and let me know the item numbers you require part numbers for.
renel
Exactly right Marc;-)..I have a Polish partscatalog from CatCar and could not find it. I need part no´s 2, 20, 71 and 5, all is a part of the window latch.
Thanks René
Thanks René
- x 6960
I'd forget those other catalogues - they 11 years out of date and Citroen don't provide these free - so they are using out of date info!
Here you are:
(2) Bearing, Rear Windscreen Wiper Shaft, part: 6405EE, £190.03
(5) Wiper Shaft Cap, part: 6405EG, £5.02
(20) Wiper Motor Spacer, part: 9810590380, £7.73
(71) MUL Flanged Nut, part: 450343, £2.33
Here you are:
darbuck
- x 291
Hi Marc, can you give me a part number for a heater core for my 508 please.
Darren
- x 6960
(1) Car Heater, part: 6448W9, £216.62
darbuck
- x 291
GORAX
- x 14
I have now bought the spare parts. I have now installed it too. But it's a kind of clip connection? To the air filter Box? For part 6GiveMeABreak wrote: 26 Oct 2024, 20:52
(3) Is the Air Intake Pipe and this may be hidden under the trim, but it has the simple plastic rivet-clips (4) shown top left, part: 1622749580. So maybe this has come loose or broken off causing the noise?
GOOGLE TRANSLATE
