- x 6945
Ok, so left and right cables, each different sizes. I'll include both for future ref:
(9) Secondary Brake Cable, (left) Long 1295, Part: 4745H5 (NFP)
(10) Secondary Brake Cable, (right) Long 1335, Part: 4745G6 (NFP)
Alternative Secondary Brake Cable, (right) part: E074005 (NFP)
Skull
- (Donor 2026)
- x 381
Thanks very much Marc - very prompt
Gary
Gary
508c5
- x 4
Hello,
Can I pls. Have the part number for the throttle body of a Citroen c4 Picasso, 1.6 petrol, 165bhp vin number VF7**************[VIN obfuscated, can be read by forum staff]
Thx
Thx
- x 6945
(5) Air Intake Throttle Valve Housing, part: V867527880, £468.65
Stijn
- x 3
Hi Mark;
I'm looking for the LDS reservoir for VF7**************[VIN obfuscated, can be read by forum staff]
Thanks in advance
Thanks in advance
508c5
- x 4
Hello
What is the OE part numbers for the front and rear breaking system (discs and pads) for a Citroen Picasso c4 (5 sitter) , 2018, 1.6 petrol with the vin number VF7**************[VIN obfuscated, can be read by forum staff]
Thx
Thx
- x 6945
(1) LDS Reservoir, part: 4009V8, £99.53Stijn wrote: 22 Oct 2024, 20:11 Hi Mark;
Thanks in advance
- x 6945
Front Brakes508c5 wrote: 22 Oct 2024, 20:40 Hello
Thx
(1) OEM Ventilated Brake Disc Diam 304 EP 28, part: 4249K1, £156.85
PSA Cheaper Front Disc, part: 1687772080, £78.42
(4) Set of 4 OEM Front Disc Pads, part: 1647863680, £149.98
Rear Brakes
(1) OEM 2 Disk Kit Pro Diam 290 EP 12, part: 1609583080, £165.68
PSA Cheaper 2 Disk Kit, part: 1687772680, £121.76
(2) OEM Brake Pad Kit, part: 1647860380, £114.79
Cheaper PSA Kit, part: 1619791280, £53.63
cupofcoffee
2004 Citroen Xsara Picasso Exclusive Diesel 1.6
Hi Marc,
The light bulb behind the speed display has gone.
Can you tell me please what sort it is, or if it has a part number?
With thanks,
Stephen
Hi Marc,
With thanks,
Stephen
- x 6945
Hi
These are quite easy to do and I believe they are the 1.2W bulbs - so you have a choice of either getting a pack of the bulbs from ebay or somewhere and replacing them using the existing holders, or purchasing the bulb and holder - which are quite expensive to do as there are a few in there.
(10) Bulb Holder, part: 611256, £7.67
If this picture is anything to go by they may come in a pack of 10 (I would hope so for that price):
Just remove the covering panel at (1):
Then remove the screws at (2) & (4) and gently release but mind the cables.
So better just getting a pack of 1.2W bulbs and just replacing them using the existing holders - as shown here:
moizeau
- x 423
Hi Marc, just took my Disapatch for tracking and it couldn't done due to the RH trackrod end and the LH wishbone ball joint being knackered. From what I've seen the complete wishbone needs to replaced. Could you do the honours please?
Cheers
Cheers
Pete
- x 6945
(2) Wishbone Front (left)
OEM Original. part: 3520R8, £370.15
PSA Cheaper Option, part: 1635773680 (No Longer Available)
(1) Steering Rod Connection Kit, part: 3812F0, £168.32
PSA Cheaper Part: 1635770480, £56.17
(3) Steering Rod Ball Joint Kit
OEM Original, part: 381773, £162.56
PSA Cheaper part: 1635772880, £47.87
moizeau
- x 423
Thanks Marc, much appreciated.
Cheers
Cheers
Pete
GORAX
- x 14
Hello everyone,
The air filter box in my car is loose. It rattles when driving. Are there any mounts for this in my engine compartment? I saw a piece of metal in a picture that wasn't there. Could that be the reason? I marked what was missing in blue. Are there any others missing from the air filter box?
The foam also came off. Where can I buy it from?
Unfortunately I can't upload the video where it rattles.
- Attachments
GOOGLE TRANSLATE
- x 6945
(3) Is the Air Intake Pipe and this may be hidden under the trim, but it has the simple plastic rivet-clips (4) shown top left, part: 1622749580. So maybe this has come loose or broken off causing the noise?
