Activated V6 driver
Koukku
x 8
Re: Activated V6 driver
Unread post by Koukku »
A little update on this V6 Activa, better late than never... the rust at the rear end of the sills caught up quite fast later in 2018 (no it was not just on the surface as I hoped back then), and I had to take the Sensible Daily off the road. Me not speaking fluent welding meant either an expensive trip to a body shop, or try and to sell it as it is. Scrapping it or parting it out wasn't really an option. It took a good while, but I did find a buyer for it from our Citroen club. He had the rear suspension arm bearings an the sills fixed in about a week, and this V6 Activa lives on to make future drivers take corners with a grins on their faces!
I did have it running on E85 in the end. I did the "start with 50% E85, then 75% and finally 100%" procedure, and it ran ok. No hiccups, no warning lights. Consumption went up by about 30% which was exptected. Only when going WOT at high rpm it hesitated a little, meaning the injectors were not flowing enough fuel, and it went a little lean. At about 75/25 mix of E85/95E it was all good. But when the weather got cold, like below +10°C, it would take three tries to do a cold start, and it would run pretty rough for the first few minutes. So I switched back to all gasoline. So yeah, the ES9J4 ECU can handle driving with E85 without modifications, injectors not so much. Also the cold start enrichment would need to be sorted.
I went on to buy a 1992 Clio S as a winter beater. What a fun little car. Absolutely no extra features to go wrong. And I got to learn how to adjust valve clearance. But then the cam belt failed mid winter, and I had to dig up the good old Mini R53 (the same one I bought back in 2012) from the garage. I found myself again selling a car in a rather sad state, but again managed to find a buyer. 120€ and a bottle of terrible whisky was the haggled price. Enthusiast are a strange bunch.
I didn't want to drive the Mini in the winter any more, so in late 2019 I bought a 2001 Xsara Break in Exclusive trim and with 2.0 gasoline engine. Unbelievably reliable motor. I only planned to drive it for one winter, but it's still here going strong. It is in dire need of new winter tyres, though, and that gave me an excuse to start looking for yet another sensible daily. So tomorrow I'm going to take a three hour drive to see a Xantia... not an Activa this time, but still a rare bird: V6 estate with a manual gearbox. :)
- Previously Activated -
x 1996
Unread post by Stickyfinger »
V6 estate with a manual gearbox......another car the UK did not get :(
Koukku
x 8
Yup, you got really unlucky on that front. Peugeot managed to make RHD manual V6's at the time, was it the hydraulics that Citroen didn't bother to relocate on the V6?
Anyway, the car I went to see drove beautifully, made all the right noises when given a bit of left foot, and had a leather interior in decent condition. Heater core had been replaced, and the cam belt had 5 years of life left in it. Unfortunately the sills were in a pretty sad state, and rest of the exterior looked like it had gone through at least one apocalypse... so I went and bought a set of winter tyres for the Xsara.
But I haven't stopped looking for manual V6's. Let's see what comes up.
x 8418
Great to read your update Koukku :D My dream car was always a V6 Xantia Activa Estate!
Koukku
x 8
Oh yes, that would be the dream, I'd take a Bleu Mauritius or Rouge d'Enfer car with the elusive leather/alcantara seats...
There was that one estate in Germany that was converted with Activa bits, but haven't heard from it in ages. One guy in Finland put an estate rear axle on his Activa, that was quite a lot of work too.
x 8418
Koukku wrote: 21 Oct 2024, 08:19 Oh yes, that would be the dream, I'd take a Bleu Mauritius or Rouge d'Enfer car with the elusive leather/alcantara seats...
The Rouge d'Enfer one would be the icing on the cake!
Koukku wrote: 21 Oct 2024, 08:19 There was that one estate in Germany that was converted with Activa bits, but haven't heard from it in ages. One guy in Finland put an estate rear axle on his Activa, that was quite a lot of work too.
I remember that one... Love to know what became of it and it it is still extant... I would very much imagine it is, being such a special car...
x 1996
Based on my poor memory......I read that it was sold and proved to be rather "iffy" with some concerning modifications/ or/ condition of the bodywork
x 8418
Stickyfinger wrote: 21 Oct 2024, 13:27 Based on my poor memory......I read that it was sold and proved to be rather "iffy" with some concerning modifications/ or/ condition of the bodywork
That's not good news Alasdair... Hope it wasn't terminal...
x 1996
[If I recall correctly] it was about the rear subframe/changes needed to mount the Active Ram.
x 8418
Stickyfinger wrote: 21 Oct 2024, 19:00 [If I recall correctly] it was about the rear subframe/changes needed to mount the Active Ram.
Ahh yes, as I believe Hatch and Estate rear subframes are sufficiently different and thus not interchangeable so the estate one would have to be modified rather than just transplanting an Activa subframe from a Hatch...
x 1996
Yes, a lot less room all over really
Koukku
x 8
IIRC the guy in Germany just swapped an Activa rear subframe on the estate. The estate subframe is stronger, probably for a reason.
x 1996
I did not think it was a direct swap.....
