DIY Car Maintenance with function over finesse!!
- x 8126
Re: DIY Car Maintenance with function over finesse!!
The first component for my project has arrived today and will be mounted on the shelf between the power outlets!!
Skull
- (Donor 2026)
- x 381
Is it a variable matrix glitch control to sort out the 'diy/motoring function over finesse' thread merging ...most confusingmickthemaverick wrote: 15 Oct 2024, 09:34 The first component for my project has arrived today and will be mounted on the shelf between the power outlets!!![]()
Gary
Gary
- x 8126
Sorry Skull, this latest post refers to the project I began before we transferred Ryan's exhaust issue here!! More to come on my project very soon, any more guesses are welcomeSkull wrote: 15 Oct 2024, 15:18Is it a variable matrix glitch control to sort out the 'diy/motoring function over finesse' thread merging ...most confusingmickthemaverick wrote: 15 Oct 2024, 09:34 The first component for my project has arrived today and will be mounted on the shelf between the power outlets!!![]()
- x 3296
Is that the adjustment potentiometer for the Planck's Constant recalibration device?
- x 8126
The next clue proper will be along shortly but here's the unit installed:
- x 8126
The next clue proper is here!!
- x 2342
Woohoo! It's a hollow victory to be honest!Rp0thejester wrote: 14 Oct 2024, 19:11 I'll grab some photos tomorrow, I'm determined to fix her as I have 1 car and 0 roadworthy at the moment. That means Matt's 7 cars and 2 roadworthy, percentage wise, is beating me!!!![]()
Sorry I've nothing definitely constructive to add.
Rough ideas:
- split rear section from DPF to reduce weight that's is fighting you?
- daft question, but you are attempting to hold both ends of it? I.e. nut and the "ball end" both. Think is 10 mm hex on both ends. The bolt will spin in the recess in the exhaust flange.
- nut splitter to disable the nut without caring if it spins?
- x 1072
Nut splitter!! Why didn't I think of that, thx I'll look into it
Champion of Where's CitroJim
- x 1072
Mick, why are you running up a strimmer head? Using what I would call a variable resistor?
- x 8126
There's a bit more than just the pot in the blue box but that's to allow it to handle 4kW without melting! As to why that is part of the ongoing guessing game!!
- x 1072
Is it to control the speed of your electric jack?
- x 8126
That's a good thought Ryan but no, the jack is 12V DC.
- x 1072
I'm not good with electrics but wattage is to do with power drawn?? So that makes me think it's gonna be under load at some point. So I'm thinking....tyre inflator!!
- x 8126
Yes I like your thinking, which is on the right lines but not tyre inflater. I will add another visual clue tomorrow when another parcel arrives!
- x 8126
Just waiting for one more component so I can start assembly but here's a mock up which should give the game away!!
