P0135 OBD-II code
Blue007
P0135 OBD-II code
Unread post by Blue007 »
Hi everyone
Dispatch 2.0L xl 2008
P0135 OBD-II code
O2 sensors heater circuit malfunction bank 1 sensor 1
Trying to find were the fuse would be( to check first before changing the sensor) looked in manual & obviously Googled to no avail,
Any help appreciated
Blue007
x 1496
Re: P0135 OBD-II code
Is this a 2.0 diesel? Is the engine management light on?
Blue007
Hi Richard
Yes 2.0L but no light on dash,
Thanks for the reply
Blue007
Just a update
Went for the mot yesterday and spoke with the guy
Who the put the old laptop on,malfunction in the glow plugs. Or the relay.
x 1496
Ah, it's probably P1351 - it comes as std on pretty much every HDi, but for Citroen / Peugeot doesn't usually cause any issues.
Blue007
Thanks for the reply RichardW
Yes he said if its 1 glow plug it be ok but 2 would have problems starting in colder weather,
So will get it sorted in couple of weeks
Blue007
Just done a full service,
Took it for a spin,drove good, started it up again got codes..P0102/P0113/ P0238 x2 also anti pollution fault.can anyone explain current low input compared to current high input please.
Clean the Maf sensor/Iat sensor
Thinking buy to new sensors( any ideas on oe types)
Nothing from ecp thanks.
Thanks I advance
Ste
PaulC5
x 701
Unread post by PaulC5 »
Possibly there is a problem with the MAF sensor, the MAP sensor, the wiring/connections. Have a look at live data to see if the values are reasonable and the freeze frame data stored when the last fault code was given.
Blue007
Hi PaulC5,
Thanks again for your reply,
Cleaned maf again plus electrical contacts( male)
Seems to have sorted it,
