Citroen Xsara N1 front heated seats wiring diagram
T3nkata
Unread post by T3nkata »
Hello, guys,
I bought original front heated seats for my Citroen Xsara N1. I have part of the harness for them but most of the wires are cutted.
So, I am searching for a wiring diagram for such seats. The car is Citroen Xsara N1, 1.8 8V, 90 h.p., 1998 year.
Thanks in advanced! :wink:
x 6956
Re: Citroen Xsara N1 front heated seats wiring diagram
You will need to provide a VIN first. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
T3nkata
The VIN is VF7**************[VIN obfuscated, can be read by forum staff]
x 6956
Layout
Wiring
With the exception of the wiring codes, most of the component codes are indexed here:
PSA Electrical Diagrams - Wiring & Symbols Codes Index
T3nkata
Thank you!
T3nkata
Hello,
Is there any other type of wiring diagram_ I am asking because mine is original one and some of the connection that were not cutted when the seats were removed are not the same as in the attached diagrams above.
Thank you in advanced,
x 6956
I can only provide you with the specific diagram for the specific car.
T3nkata
Could you please check diagrams for the following VIN: VF7**************[VIN obfuscated, can be read by forum staff]. Thank you.
x 6956
You should be aware that the Xsara II has different vehicle electronics to the MK I, so I can't advise whether this will have implications or not....
Change to the multiplexed design
The XSARA has a new electrical layout and a new BSI incorporating:
  • A COMFORT VAN gateway (transfer rate: 125 kbits/s)
  • A BODY VAN gateway (transfer rate: 62,5 kbits/s)
  • CAN gateway (transfer rate: 250 kbits/s)
T3nkata
Thank you.
