Peugeot 5008 (2018) 1.5BlueHdi, manual gearbox - official maintenance plan
RuiV
Unread post by RuiV »
Hi all.
Can anyone help me to get the official maintenance plan and schedule (the what and when do). I tried to get it from the dealer... no luck. I have the Haynes manual... well, poor, very poor.
Thank you in advance
x 6948
Re: Peugeot 5008 (2018) 1.5BlueHdi, manual gearbox
I can't give you what is done in every service as that depends on the type of service (Minor / Intermediate or Major), but here are the main items for your specific 5008:
SERVICING / Normal conditions of use
SYSTEMATIC OPERATIONS
Servicing: Systematic operations Every 30000 Km / 1 year(s)
ADDITIONAL OPERATIONS
Replacement of the brake fluid Every 2 year(s)
Replacement of the fuel filter (diesel) Every 60000 Km / 4 year(s)
Replacement of the air filter Every 60000 Km / 4 year(s)
Replacement of the passenger compartment filter Every 60000 Km / 2 year(s)
Check of the PH of the coolant 120000 Km / 4 year(s) Then every 30000 Km / 1 year(s)
Check of the clogging of the particle emission filter 180000 Km Then every 30000 Km
Replacement of the ancillary drive belt Every 120000 Km / 6 year(s)
Replacement of the timing kit and of the coolant pump Every 180000 Km / 10 year(s)
Replacement of the ancillary drive belt kit Every 180000 Km / 10 year(s)
AUTHORISED ENGINE OILS
00W20 B71 2010 (C5)
RuiV
Re: Peugeot 5008 (2018) 1.5BlueHdi, manual gearbox - official maintenance plan
Thank you.
Mihael_M
x 37
Unread post by Mihael_M »
Hallo Mark , on Your list :
When should it be changed? 120,000 km is early ?
x 6948
@Mihael_M
Not for these engines - later engines are designed differently, with many running faster, hotter and are more compact, so these are the official intervals which must be adhered to and changed whichever comes soonest - age or mileage.
