= Pink = Red = StrawberryRp0thejester wrote: 06 Oct 2024, 21:04![]()
strawberry is a terrible name, strawberrys are more pink, bluebell I can understand.
- x 1995
- x 1074
Nah, that's Rudolph
Champion of Where's CitroJim
- x 8126
Treading on dangerous territory there Ryan, Strawberry was Jim's grand daughter Autumn's idea!!
- x 1074
Oh in that case it works PERFECTLY!!! I see what you all mean now, definitely strawberry coloured!!.....
- x 8409
MattBLancs wrote: 06 Oct 2024, 19:32That's right Ryan, officially known as Strawberry there's a red AX joined the fleet.Rp0thejester wrote: 06 Oct 2024, 19:14 Am I reading this right? Has bluebell now got Rudolph as company?
If Jim gets them parked just right, and we all put a pair of these on:
- Spoiler: show
You'll also see Strawberry has a special place to live in Ryan
Skull
- (Donor 2026)
- x 382
Parkrun 20th Anniversary milestone at Darlington with a 100th park run and someone from Australia
Gary
Gary
- x 8409
Magic
Been busy today... A trip to Tesco early on whilst a loaf of bread proved, then a run around town whilst it rose ready for baking followed by a trip to B & Q to procure some essential house maintenance items, including, and not limited to, a bag of ready-mixed screed...
I have 25Kg - smallest bag available - of it and will possibly use about a quarter of it
I also got the stuff to install a proper tumble drier exhaust vent in the conservatory and the stuff I needed to fix a small leak in the conservatory roof...
Both tasks now complete...
The final item purchased was tape to re-wrap my gas pipe before it disappears again under the new layer of screed.
Meanwhile, checks on Strawberry shows she's now nicely oil (and grease) tight after a good few miles
And her having no radio is no problem; I'm happy to drive any distance without and nowadays often turn off Polly's and Bluebell's and drive in peaceful silence...
Bluebell is due her MoT in a month so very soon I'll be booking her in and getting her ready for it...
- x 2355
Ha ha, we could have done a swap gearbox oil for your excess sand and cement mix!
Equally I could have fetched you some of that when we met up too!
- x 8126
Back atya!!
- x 8409
Didn't know I'd be needing it then MattMattBLancs wrote: 07 Oct 2024, 15:11 Ha ha, we could have done a swap gearbox oil for your excess sand and cement mix!
Equally I could have fetched you some of that when we met up too!![]()
How long does it keep if kept in a well sealed bag?
- x 8126
A fair while if you keep it away from cold and damp Jim, I've used some that had been in the garage sealed for 9 months and it was fine.
- x 8409
That's good to know Mickmickthemaverick wrote: 07 Oct 2024, 17:25 A fair while if you keep it away from cold and damp Jim, I've used some that had been in the garage sealed for 9 months and it was fine.![]()
- x 2355
It's ingress of humidity that does for it, if you can plastic wrap it (or shrink wrap / cling film even) that should slow down the moisture
- x 8409
I have the ideal thing Matt, a big roll of industrial clingfilm. The stuff they use to wrap pallets...MattBLancs wrote: 07 Oct 2024, 22:12 It's ingress of humidity that does for it, if you can plastic wrap it (or shrink wrap / cling film even) that should slow down the moisture![]()
moizeau
- x 423
Use a black bin liner as a final wrap to keep light out, keep it off the ground and airtight and it will last for ages
Pete
