Bit of a quandary
My X7 has just done 2300 miles and the autobox has behaved impeccably. The car has 160,000 miles and no evidence of any work done on the box in the (pretty complete) service history.
So I'm torn between doing a partial change or just leaving it alone. Could a partial change introduce any problems that are not there at the moment?
If I do a partial change do I reset the counter with Diagbox?
What would you do?
C5 X7 Auto - do I change the fluid?
steveclv
- x 40
- x 6956
Re: C5 X7 Auto - do I change the fluid?
That's a long time if on the original oil. Personally, I would give it a complete change - which if you follow the video is the best way.
See my post here with the video to watch:
viewtopic.php?p=806256#p806256
The same grade also applies as you have a Euro 4 vehicle, so JWS 3309.
Yes you absolutely must reset the oil counter, as this determines gearbox operation and takes into consideration the ageing oil.
steveclv
- x 40
OK, sounds like a plan - fingers crossed
Kees
- x 147
Here you can see the difference between the old and fresh oil change.
I did this a month ago, and my car was around 200000 Km.
I followed the video of the Volvo car.
Greetings,
Kees.
Greetings,
Kees.
