x 6945
(1) Left Suspension Cylinder, part: 5271L5, £546.32
Right Suspension Cylinder, part: 5271L6, £540.59
A horrendous price now, as parts are becoming less in demand I suspect.
Poland / Lithuania seem to be the only places that can provide a better price. Even Amazon have these for £768 each! :shock:
darbuck
x 289
Unread post by darbuck »
Hi Marc, can you give me the part number for the fuel metering valve for my 508 please?
Darren
x 6945
What the fuel regulator? - Or the fuel rail pressure sensor?
(1) Regulator, part: 193339, £215.41
darbuck
x 289
Thanks Marc that's it. I bought it knowing this needed changing so no Biggie.as far as I know they're the same as the 138bhp in the C5. I just want to cross check it to make sure.
Darren
darbuck
x 289
Hi Marc can you give me a part number for the key for my 508 please
Darren
x 6945
The transmitter module (with combination specified and cut on order) is part: 1609365180, £186.25
The transmitter module with raw uncut key is part: 1609365280, £158.24
dylan26__
x 22
Unread post by dylan26__ »
Could I please get the front control arms for ds3 : VF7**************[VIN obfuscated, can be read by forum staff]
x 6945
(5) Wishbones
OEM Original Left, part: 9847585980, £162.88
OEM Original Right, part: 9847585880, £220.98
Cheaper Left, part: 1682735380, £95.50
Cheaper Right, part: 1682734580, £129.54
darbuck
x 289
GiveMeABreak wrote: 30 Sep 2024, 14:23 The transmitter module (with combination specified and cut on order) is part: 1609365180, £186.25
Thanks Marc
Darren
Huskyxantia
x 908
Unread post by Huskyxantia »
GiveMeABreak wrote: 30 Sep 2024, 14:39 Image
(5) Wishbones
Are these the same as a c3 picasso ?
:-D
Huskyxantia
x 908
If not regarding the above, can i have part numbers for lower wishbones
Drop links , top outter & inner tie rods , hers my vin VF7**************[VIN obfuscated, can be read by forum staff]
Thank you for your help & time marc , regards Husky
:-D
x 6945
No, different part numbers.
Delion
Unread post by Delion »
Hi Marc,
Looking for part number for the following.....
Front left hand door handle
C4 Picasso Exclusive+
Vin VF7**************[VIN obfuscated, can be read by forum staff]
Thanks in advance
Del....
x 6945
Hi Del
(2) Door Handle (Left), with hole - to be painted, part: 967853211T, £195.04
Delion
Cheers Marc.
That now confirms 967853211T is the replacement for the original part 1606874580 which is chrome and black and the one I need, luckily I've found one in good condition. The handle on there at the moment locks ok but it's hit and miss on opening, fingers crossed the one that's coming works ok as you never know.
Thanks for you help
Del....
