Whatsthisthen?
x 2362
Re: Whatsthisthen?
Unread post by MattBLancs »
D'oh, too slow off the mark, I knew the orienteering thing was an orienteering thing!
No idea on the precision swiss whatchamacallit!?
x 1998
Re: Whatsthisthen?
Unread post by Stickyfinger »
The bottle IS empty, that is the light/glass showing the white tissue the bottle is resting on....
NOT a burner/nothing to do with heat/flames or any form of combustion/heater etc
x 1472
Re: Whatsthisthen?
Unread post by xantia_v6 »
Is it some kind or reamer, hone or cleaning device?
x 8145
Re: Whatsthisthen?
An injector spray pattern tester? :-D
x 1998
Re: Whatsthisthen?
reamer, hone or cleaning device.........nope
Not spray connected....or anything to do with testing or calibrating things
x 1472
Re: Whatsthisthen?
is it a device for testing the purity of some substance?
x 1998
Re: Whatsthisthen?
No, but the material it is made from is a highly refined Ti alloy
x 8145
Re: Whatsthisthen?
Anything to do with dentistry? :)
x 8145
Re: Whatsthisthen?
Cigarette filter maker for rollups? :-D
Re: Whatsthisthen?
Back to tot up the guesswork, bit more forensic questioning required or Alasdair is going to get to the finishing line and win pretty quickly. My last question was number 6 after that we have had
No 7
xantia_v6 wrote: 29 Sep 2024, 16:22 Is it some kind or reamer, hone or cleaning device?
...nope
No 8
mickthemaverick wrote: 29 Sep 2024, 16:24 An injector spray pattern tester? :-D
...Not spray connected....or anything to do with testing or calibrating things
No 9
xantia_v6 wrote: 29 Sep 2024, 20:15 is it a device for testing the purity of some substance?
...No, but the material it is made from is a highly refined Ti alloy
No 10
mickthemaverick wrote: 29 Sep 2024, 21:18 Anything to do with dentistry? :)
Awaiting reply
No 11
mickthemaverick wrote: 29 Sep 2024, 21:29 Cigarette filter maker for rollups? :-D Awaiting reply
Only 9 to go...time to think of questioning to get us closer rather than random guesswork.
x 1998
Re: Whatsthisthen?
10...yes
11...nope
x 8145
Re: Whatsthisthen?
Then a device for mixing the old fashioned filler, the name escapes me?
x 1998
Re: Whatsthisthen?
if you refer to "fillings", then = Amalgam.....so Nope.
x 8145
Re: Whatsthisthen?
Dental implant tool ? :)
x 1998
Re: Whatsthisthen?
It is not a tool of any sort
