Lighter electrical problem
macaroni
Unread post by macaroni »
Can anyone shed any light on this problem...
The lighter in Xantia doesn't work, I want to power a mobile charger of fit.
Upon checking the fuse, as advised in the handbook, I found that the fuse controls the car stereo, aswell as the correct fuse for controlling the car stereo.
Is my wiring totally screwed or am I doing something wrong?
Any help gratefully received.
Antony
uhn113x
x 3
Unread post by uhn113x »
Antony
What happens if you stick a bulb across it? Or even a meter - at the moment, a digital voltmeter is £2.49 (yes!) at Maplin. :D
macaroni
Thanks for replying.
Across what? The fuse or the socket? There is definitely no power at the Lighter socket and definitely power at the relevant fuse as it powers the stereo.
x 1239
Unread post by Peter.N. »
Most radios have two supplies, one for the actual radio and one for the memory, does your radio store and retain stations and settings OK, if so both supplies are present, if not, the memory must be fed from the lighter supply.
macaroni
Ah yes. Both the fuses that control the radio ie the actual radio fuse and the one that should control the lighter, have 2 positions. I switched them to the other position and the radio memory was lost each time the ignition was switched off.
As my stereo is an aftermarket one, does that mean my Lighter fuse has been seconded for use with the stereo and thus will not work for the Lighter any more?
uhn113x
x 3
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by macaroni</i>
The socket, but it seems you have found thst already, and there is a break between it and the fuse, assuming that this is the correct fuse.
Is it possible to trace where the lead from the lighter goes?
x 1239
The 'memory' supply' comes from a permanently live feed which would be the lighter supply. If you have a meter or a bulb would do, check from the + side of the lighter (centre contact) to earth, somwhere other than the lighter, it could just be that you have lost the earth connection to the lighter.
wrinklet1
Unread post by wrinklet1 »
Marconi, I think you may find that the socket that plugs into the back of the lighter has detatched itself from the lighter. This can happen easily and you can push it back by wrigling your finger under where the lighter is and feeling for the socket, or removing the ashtray and lighter unit and refitting it that way.
Paul
PS it happened on my car too.
macaroni
Great, thanks for all the advice. I will try it, starting with the simplest by Wrinklet1.
macaroni
By way Wrinklet1, it is Macaroni, as in pasta and not Marconi as in failing electronics giant.
By the way 2, are those cars you list your current collection or past history?
wrinklet1
Sadly they are my history of Citroens that I have owned in the past Macaroni.
Paul
macaroni
Cool, saving the best until last eh?
macaroni
OK, well the earth lead was detached from the lighter, so good call there. I re-attached it and upon plugging in my phone charger, it repeatedly blows the fuse!! This charger works fine in my 205 and the Lighter thing works OK in the Xantia, but the phone charger keeps blowing in the Xantia.
Anybody any idea why?
wrinklet1
Check your wiring at the back of the lighter, thats where your problem with blowing the fuse lies or even with the 'clamps' withing the lighter itself.
Paul
