3520 W2 & 3521 S5 are old part numbers and these have been superseded with modified versions.
- x 6955
No, none of those parts are correct for your vehicle. Please stick to the part numbers I have specified, which is why we use the VIN to ensure you have the correct parts and avoid future problems.
Timmycitroen
Hi after a part number for bolt for timing belt tensioner and diagram if possible
Torx with two different threads and nut
Vin
Thanks in advance
Vin
Thanks in advance
Reason: When providing your VIN, please enter it in FULL without spaces.
- x 6955
(15) MUL Flat Washer, part: 020514, £1.70
(16) Camshaft Pulley Screw, part: 080650, £3.36
(20) MUL Flanged Nut, part: 450343, £2.33
(22) MUL Stud, part: 0341P8, £1.33
(24) Flanged TH screw, part: 9801910480, £1.36
GORAX
- x 14
Hi everyone,
I would like to retrofit a rear view camera. Could I get the part number for this? and if possible, instructions?
GOOGLE TRANSLATE
- x 6955
Sorry, as your vehicle was without this system it won't provide parts for it and you won't have the harness, or the correct ECU, nor the right Head unit or screen.
You are better off going for an independent unit with separate monitor / rear view mirror LCD combo or similar.
OnlinePaul-R
- x 1929
You could try contacting the people I suggested in this post viewtopic.php?p=813352#p813352
They seem to specialise in aftermarket rear view cameras.
cncjeff1
Hi All,
Back in to the breach. Vehicle is a 2016 Citroen Berlingo, VIN VF7**************[VIN obfuscated, can be read by forum staff]. Please provide the following part numbers:
Turbocharger
Waste Gate
Waste gate solenoid
Thanks in advance.
Best Regards,
Jeffrey
Turbocharger
Waste Gate
Waste gate solenoid
Thanks in advance.
Best Regards,
Jeffrey
- x 6955
Can't remember if I advised you previously, but your vehicle has an outstanding after-sales campaign for the timing belt system. Please quote reference HCJ to your dealer. The operation involves replacing the timing front face parts and will be free of charge. It has been outstanding since 28/02/2021.
The turbo is a complete unit as shown
(1) New OEM (MHI) Turbo, part: 9842096580, £1454.29
Exchange MHI Turbo, part: 1611139180, £916.88
(1) Turbo Solenoid Valve, part: 9811643880, £62.56
Bryonyolney
Hi!
Could you assist with the part number for the EGR hose/pipe for VIN VF7**************[VIN obfuscated, can be read by forum staff]?
I understand from my mechanic there are 2 one on top of the other - it's the bottom of the two hoses I'm after a part number for Hope that information isn't too obscure and you might be able to help!
- x 6955
You'll have to let me know which item from the diagram below:
Bryonyolney
Thanks Marc my Mechanic doesn't recognise it from the diagram so we're going to try and get a part number when he looks at it on Thursday, if we cant find a part number on the existing part I'll send some photos (he now thinks it might be part of the intercooling system rather than EGR). Thanks for your help!
- x 6955
Ok, so as you haven't mentioned whether it's an air, vacuum or water pipe I haven't a clue. So here are 4 diagrams including the original:
So let me know the item number from table A, B, C or D when you find out.
| (A) Cooling System Piping | (B) Air Filter Piping |
| (C) EGR System | (D) Turbo Piping |
DaveS
Hi guys,
Can I please have a part number for a thrust bearing. VIN is VF3**************[VIN obfuscated, can be read by forum staff]
Thanks!
Thanks!
- x 6955
(2) Clutch release bearing buffer, part: 1611271480, £59.62DaveS wrote: 26 Sep 2024, 15:31 Hi guys,
Thanks!
Gastomato
- x 3
After a the recent MOT test on my C5 X7 Hydractive, i have received marks for leakage of hydraulic fluid from the two front shock absorbers. I have heard rumours of the high cost for these, I am awaiting a reply from the garage and want to check here to get the parts numbers.
Maybe I get them from an alternative source cheaper. Hope you can help!
The VIN for my car is VF7**************[VIN obfuscated, can be read by forum staff]
