P1210 fuel pressure regulator fault
Rhothgar
(Donor 2026)
x 222
Re: P1210 fuel pressure regulator fault
Unread post by Rhothgar »
darbuck wrote: 02 Sep 2023, 20:37 Delighted for you enjoy what's left of the weekend
Inspired to do a leak off test myself...
What's good for the goose and all that!
darbuck
x 290
Unread post by darbuck »
How did your leak off test go after?
Darren
Rhothgar
(Donor 2026)
x 222
darbuck wrote: 07 Sep 2023, 19:55 How did your leak off test go after?
I didn't bother in the end but may do soon.
Rhothgar
(Donor 2026)
x 222
How's your love story going with the C5?
And more importantly is SWMBO convalescing well?
darbuck
x 290
If it's not giving trouble there's no panic and it being french will probably protest😂😂Yes she is ok she had work on her knee so uncomfortable but she's doing ok.
I pulled the steering rack out because it's leaking vast amount of lds out of both gaiters all the seals in lower section are gone so trying to source new ones. One of my wiper motors is on the blink so will have to figure out how to get the two of them sorted so that I can finally get it nctd and start driving it I got another used injector aswell so hopefully it will be sorted.
Darren
darbuck
x 290
These are the two connectors I spoke about earlier. As you can see identical the only difference being wire colours.
Darren
KennyW
x 163
Unread post by KennyW »
Darren,
So easy to mix up, when you have removed a loom. But the important thing you realised what you had done and fixed it.
Kenny
C3 1.4 petrol (SWMBO)
darbuck
x 290
Yes it's just incase someone else has a similar issue
Darren
Rhothgar
(Donor 2026)
x 222
darbuck wrote: 01 Sep 2023, 19:08 I don't think any of these injectors are any good any opinions the fastest filling is injector 3 again Even though it's replacement but it is used so Not much use I think.
I am able to actuate all injectors so it's mechanical rather than electronic.
Did you get the car sorted after your scoping last week.
This looked good! What changed? Is it worth now? If not, then it cannot be the injectors.
darbuck
x 290
I'll have to do another test I guess
Darren
Rhothgar
(Donor 2026)
x 222
darbuck wrote: 10 Sep 2024, 06:20 I'll have to do another test I guess
It would definitely make sense to do so.
darbuck
x 290
I will try and do one this evening weather permitting
Darren
darbuck
x 290
Hi Roger I done a leak off test see the results. I think we can safely say I have 2 bad injectors and one that's just about in spec I will try testing other injectors I have but I think I am going to need a couple of refurbished units.
Darren
KennyW
x 163
Darren,
Do you still have the original set of injectors and spare set or did you just get a single one ?
Kenny
darbuck
x 290
I have original injectors and a a few I bought but I'm not sure if any of them are any good
Darren
