Lights! (Interesting and Awful please)
deuchebleu
x 21
Re: Lights! (Interesting and Awful please)
Unread post by deuchebleu »
I thought the "Red" bit was meant to be a prism lens for the driver to see if the sidelight bulb was illuminated from the driver's seat
x 7168
deuchebleu wrote: 06 Aug 2024, 21:54 I thought the "Red" bit was meant to be a prism lens for the driver to see if the sidelight bulb was illuminated from the driver's seat
You may well be right...seems a decent suggestion. Bit delve into the net may confirm.
deuchebleu
x 21
Just had a quick delve and post 20 of 29 on this thread seems to confirm it.
https://forums.jag-lovers.com/t/mk2-jag ... /367563/17
x 7168
deuchebleu wrote: 06 Aug 2024, 22:40 Just had a quick delve and post 20 of 29 on this thread seems to confirm it.
Well found. :-D
Yes I was having a paddle there too! Nice name for them "Sidelight Tell-Tales"
x 8462
NewcastleFalcon wrote: 06 Aug 2024, 22:09
That's as I've always understood it. Bulb failure warning devices are nothing new ;)
x 5689
There were some cars from the fifties that had a clear prismatic light-pipe that did that although I am at a loss to name one.
x 7168
The rover P5B had a red-tell tale
x 7168
This is described as
Lucas 1130 Type Sidelamp-Red Dot-Sidelight/Clear Indicator
The Lucas 1130 sidelamp is produced in many different variants
, each have subtle differences, whether it be the lens type,
the bulb holder, addition of a Lucas emblem to the top,
or even the way in which the body is manufactured.
This particular version has a double filament
12/5 watt bulb installed, providing sidelight and
clear indicator functions. The lens is frosted glass
within a chrome mounting ring, and the lamp body
features a Red Lucas Medallion on the top, which
acts as a tell tale. Supplied complete with bulb,
base gasket and fixing bolts.
x 7168
Readers and followers of the thread should be quite familiar with the red tell-tale. This time it's on a Jaguar XK 150
x 8462
Proper lights :D
x 7168
Here is the inaugural entry on the FCF rear lighting at night spotters guide inspired by the recent whatsthisthen?
Rears only for this, as that is the view you get most commonly, and the front lighting can only be deciphered as distinctive when the car is stationery or moving slowly, and any spotters guide is completely redundant with oncoming traffic at any sort of speed through the brightness and the glare.
Rear Lighting Nightime FCF Spotters Guide
Rear lighting No1
Handlebar Moustache
Renault Megane
Rear lighting No2Rear lighting No3
Rear lighting No4Rear lighting No5Rear lighting No6
x 8175
A couple of pics from tonight's run home from dinner: :-D
VW T-Cross YUK!!
VW T-Cross YUK!!
Volvo ???  More YUK!
Volvo ??? More YUK!
x 5689
Just a load more blingyshite that does little to improve any aspect of driving or car ownership.
Have to say I haven't a clue what mine look like. My son used to collect my car at 22:30-ish and I would see if any lights were out as he drove down the street but these days I only see my car when I go to his house for it, so have never seen the rear lights. Must fix the headlight. One day.
x 7168
x 8462
That sums it up well Neil :D
