- x 8085
Evening Marc/Richard, could you please give me the part numbers for my C4 (You have the VIN) front lower control arms with bushes fitted, ball joints and drop links. Thanks in advance
- x 6956
(2) Wishbones
OEM Left, part: 1643188580, £225.89
OEM Right, part: 1643188980, £225.89
PSA Cheaper Left, part: 1693986680, £84.41
PSA Cheaper Right, part: 1693986580, £87.42
(4) Droplinks
OEM, part: 1614281180, £64.10
PSA Cheaper, part: 1634890780, £9.94
Alternative, part: 508778, £80.09
(4) Droplinks
- x 8085
Thanks Marc, and the balljoints no7 please
- x 6956
Some kits include these, so best to check depending on version you go for.
In any case,
(7) Ball Joint:
OEM, part: 364068, £46.93
PSA Cheaper, part: 1635771380, £13.72
Like this Delphi kit....
In any case,
(7) Ball Joint:
- x 8085
Thanks very much Marc, I'm doing them for the chap who bought the car off me so I'll let him know the options and go from there!
- x 1485
Ball joint won't come with the arm in this case as its screwed into the bottom of the hub. You need a very deep 41mm socket to get them out - and they can be very tight, usually easier to get the hub off and in the vice, although a decent impact gun will get them out most times. In theory you are supposed to remove the drive shaft to get access to the arm bolts (which are in from the top) - in practice I expect there is enough room to wiggle them out past the shaft once the hub is free - but I would be tempted to back off the hub nut at the start, that way if you have to remove the shaft from the hub you are not fighting the nut with it all floating about!
- x 8085
Thanks Richard, I'll bear those thoughts in mind, I'll have to see if I can find a 41mm socket as my current largest is 36mm. I'm gently going off the idea of this job to be honest!
I just realised this is on the parts thread so by all means move the last three posts to the 'Mick reaffirms his FCF qualification' thread to clear this thread from background noise.
- x 6956
The Delphi example has the Ball Joint supplied, but of course not attached. They've just photographed it in place for illustrative purposes.
NorfolkVroom
- x 5
Heya,
Could I get the parts number for all the interior lights please? Wanting to swap them all for LED rather than the Halogen they currently are.
Peugeot 3008 2014
VIN:VF3**************[VIN obfuscated, can be read by forum staff]
Cheers!
Peugeot 3008 2014
Cheers!
- x 1485
Basically they're all W5W:
NorfolkVroom
- x 5
GORAX
- x 14
Hi
Can I have the number for my gearbox and clutch? My car won't shift anymore and revs down.
PROBLEM SOLVED!
But i need the part number for termostat and something like thermocouple
PROBLEM SOLVED!
GOOGLE TRANSLATE
DaveS
Hi guys,
Could I please get numbers for
front top mounts
front shock absorbers
Clutch kit/thrust bearing/slave cylinder
Gearbox
VIN is VF3**************[VIN obfuscated, can be read by forum staff]
Cheers!
front top mounts
Gearbox
Cheers!
- x 6956
(1) Engine Outlet Water Tank, part: 9849443980, £339.56GORAX wrote: 02 Sep 2024, 16:11 Hi
PROBLEM SOLVED!
- x 6956
(8) Shock Absorber Bracket (Left), part: 1612735980, £77.23DaveS wrote: 03 Sep 2024, 17:23 Hi guys,
front top mounts
Gearbox
Cheers!
Shock Absorber Bracket (Right), part: 1612736180, £75.94
(14) Support, Left, part: 1607114480, £29.35
Support, Right, part: 1607114580, £29.35
(1) Front Damper, OEM, part: 5208L2, £161.82
Cheaper, part: 1674697680, £122.41
(1) Pro Clutch Kit, part: 1611272780, £561.66
Exchange Clutch Kit, part: 1606888180, £305.21
(11) Clutch Slave Cylinder, part: 1609015780, £
