Hi guys !
ive been offered a 94 (M) 2.0T 605 auto on the cheap with no T & T bit tatty but nothing a trip to the scrappy couldnt fix and i would like to know is there anything i should look out for and how much do they usually go for ?
thanks Ayden
2.0t auto 605
- My Cars: Current - Slightly modified 2016 Pug 308 Puretech 130 Allure
Past:
2003 - 206 GLX TU3JP & 206 SE ET3JP4
1995 - 405 Executive XU10J2
1996 - 406 GLX XU10J4R
1994 - 405 GTX XU10J2 - x 1
Hi
Check the turbo isn't blown, They do have a high failure rate & finding a 605 / 406 / Xantia 2 litre turbo to rob engine parts off is difficult.
Make sure the auto box is working ok, Check all the electric's are working, Check over the whole car & dont pay too much for it, I wouldnt give more the £100 for it myself!
Also if it has the keypad immobiliser fitted, Make SURE you get the 4 digit security code from the owner!
1994 M plate was change over year time too, If it has the drivers airbag its the later facelifted car.
605s are rare on the road, But fixing a broken / dodgy one can be a wallet draining experience!
hi thanx for the advice i havent managed to check the whole thing over today but i did have a drive in it drove nice all the gears changed smoothly no warning lamps lit up while i was driving probaly would of been quieter if it didnt have a blown backbox apart from that it looked in decent order tomorrow tho i will fully check it over how can i check to see if the turbo has gone ??
Past:
Hi
Just check for smoke from the exhaust, Does the engine pull nicely?
Its only a 2 litre 8 valve with a low pressure turbo, 155 bhp from the factory.
Dont expect sports car performance from it, But it should move pretty quickly if you put your foot down.
Im not too clued up on the turbo engine, But I have a mate whos works for Peugeot & he replaced 3 of those turbos last year on 406s.
