Hello everyone
I have a Peugeot 5008 Exclusive 1.6 HDI from 2010 and the Power windows are not working from the driver/master switch only.
The car entered in safety mode because of the warning Anti-pollution system faulty and another 2 fault codes and I replaced the EGR valve, the turbo pressure electrovalve control, and the flowmeter sensor.
To do that I disconnected the battery and after replacing everything and when connecting the battery back the power windows stopped working.
They work fine individually from the respective door but not from the driver switch.
They also do not work when I am locking the car and the windows are down.
Can someone give me some ideas on how to solve this problem?
Thank you
Peugeot 5008 Exclusive 1.6 HDI (2010) - Power windows
Telpsantos77
- New User
PaulC5
- x 712
Re: Peugeot 5008 Exclusive 1.6 HDI (2010) - Power windows
If it is related to the battery and how you disconnected/reconnected it, you could try a BSI reset. If it is not that then maybe there is a wiring problem between the door and pillar.
viewtopic.php?f=51&t=61997&sid=f0030690 ... 4aff4c0478
- x 6950
...or one of the underside of the driver's door control pad connectors has come loose. Slamming the doors can cause the connectors to come loose. Take the door card off and check.
