Android Auto option 'missing' from C3 2017 Wave 2.1 RCC
Yakubve
Re: Android Auto option 'missing' from C3 2017 Wave 2.1 RCC
Hello,
Instead of create a new topic i would like to ask you guys if there is some posibility to get a carplay on this radio
- x 1939
Both photos are completely black for me.
Yakubve
Sorry u edit them to smaller one.
- x 5672
PM'd him and he has fixed it.
- x 6945
Please provide your VIN so I can see what you have installed. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.Yakubve wrote: 16 Aug 2024, 11:04 Hello,
Yakubve
Thanks,
VIN is: VF3**************[VIN obfuscated, can be read by forum staff]
Yakubve
Thanks,GiveMeABreak wrote: 16 Aug 2024, 18:51Please provide your VIN so I can see what you have installed. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.Yakubve wrote: 16 Aug 2024, 11:04 Hello,
- x 6945
Ok so you have a Connected Analogue Mono Radio, so if CarPlay or AA is not already available when plugged into the USB port and pressing the button as show, then it's not available. Your specifications state 'Without Mirror Link', so without this, it's unlikely you will get it. You may need the colour RCC to get this or the NAC system.
Yakubve
GiveMeABreak wrote: 16 Aug 2024, 20:05 Ok so you have a Connected Analogue Mono Radio, so if CarPlay or AA is not already available when plugged into the USB port and pressing the button as show, then it's not available. Your specifications state 'Without Mirror Link', so without this, it's unlikely you will get it. You may need the colour RCC to get this or the NAC system.
So if i buy and rcc a2 from Junkyard and code it will it work? Do i need to buy excatfly from a peugeot 308 or i can buy rcc for example from citroen?
- x 6945
I can't answer that for sure - you really need to get confirmation from the dealer first of all before going to the trouble. You won't be able to code it for your vehicle options I suspect either as it's a 'locked' module. A dealer won't do this as it's not OEM equipment most likely. Once you have it confirmed that a Colour RCC unit will work, you may have to look elsewhere for 'unconventional' access to the unit.
Albertk
I Jjust updated it with the software of citroen to 076c version and now android auto is availableGiveMeABreak wrote: 30 Jul 2024, 16:50 I've checked your VIN and there is no newer version showing as available.
So there was a newer version of software.
- x 6945
You never answered my last post - I did offer this later firmware to you, but you never replied....
GiveMeABreak wrote: 30 Jul 2024, 20:43 There's no guarantee, but I can provide you with the earliest available update I have if you want to give it a try. Obviously the choice is yours.
Husso
Hello everyone
Iv got a van 2017
HMI version: 20.522.45.4.0 iMX version: x0011046_161020_15.7A133.5 V850 version: W2.0_16.1C26.1
Got the mirror link
And apple car play, apple works
Android doesn't due to mirrorlink
Would I be able to use a android phone on this system, update or new hardware thanks in advance
Iv got a van 2017
Got the mirror link
- x 6945
I'll need your VIN to check for an updated firmware. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
rui_saraiva
- x 63
Given those versions, it's a very old RCC Wave 2 system, probably this one:
In the previous menu screen, you should see a "System version: vvvx", where "vvv" is the version number (probably 12F), and "x" a letter from A to D, the hardware capabilities/revision. Only the C and D versions support Apple CarPlay and Google Android Auto (what PSA/Stellantis calls MirrorScreen):
Code: Select all
"updateType": "rcc-firmware",
"updateVersion": "0_12F_15.7A133.5",
"updateProvider": "BOSCH_CAR_MULTIMEDIA",
"updateId": "005315191477041014",
"updateDate": "2016/10/21 11:37:44",
"updateStatus": {
"code": "DEL",
"label": "Supprime du serveur"
}| RCC | Only AM/FM | Also DAB |
| No MirrorScreen | A | B |
| With MirrorScreen | C | D |
