RoosterBooster
Unread post by RoosterBooster »
GiveMeABreak wrote: 02 Sep 2022, 13:01
(7) 7518G6 (18X40), £0.83p
(9) 7518S2 (90X180), £25.93
(10) 7518H2 (20X50), £2.89
(12) 7518J3 (DIAM 75), £3.04
(14) 698852 (37X65), £3.71
(17) 7518R8 (20X45 SHEET METAL), £0.86
I don't suppose I could ask you to confirm a part number for #20? It looks suspiciously like the blanking cap for the holes on the underside of the sills of a 207SW (roughly 45mm by 20mm) ... [VIN VF3**************[VIN obfuscated, can be read by forum staff]]
x 6946
Hi, they are different types for your vehicle and no number (20), so if any of the following, let me know the item number:
Rhothgar
(Donor 2026)
x 221
Unread post by Rhothgar »
Morning,
Could I have the part number for the abs sensors for the 3008 please?
Whilst writhing around under it yesterday, I noticed some holes in the underside of the sill and rather fortuitously I see someone else has asked about blanking plugs. Would the blanking plugs be the same I wonder? I am guessing they wouldn't reinvent the wheel but may be wrong of course.
x 6946
(1) Wheel ABS Sensor (Front), part: 4545K3, £90.36
(2) Wheel ABS Sensor (Rear), part: 4545K8, £92.11
RoosterBooster
GiveMeABreak wrote: 14 Aug 2024, 22:53 Hi, they are different types for your vehicle and no number (20), so if any of the following, let me know the item number:
That's curious ... the blanking caps which are still attached to the car look very like #20 in the original image.
Top view ...
Topside view
Topside view
... and from the underside ...
Underside view
Underside view
... which measures as 45mm by 20mm.
Out of curiosity, could you indulge me with a part number for #20 in the original image?
x 6946
Sure, the item (20) plug for Pete's 407 is part 7518R2 (20x45) and are sold in packs of 10, £0.96 each, so likely to be £9.60 for a pack.
I've checked again on the body plugs for your vehicle and the only one shown with this measurement of 20x45 is item (17), part: 7518R8, £9.70 for 10:
Closer picture here:
My guess is that they probably were using up older stock and as they are of the same dimension used these, but this is what is showing for that part now.
x 2361
Unread post by MattBLancs »
MattBLancs wrote: 12 Aug 2024, 20:32 Good evening,
Could you confirm the quantity ** / type of Eolys DPF fluid for the blue 308 SW (vin VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] ) it tells me it's got zero Milliliters left!
If there's a picture of the tank or squidgy pouch thing approximate location that'd be fantastic too,
DiagBox suggests 1.35 litres,
It also stated all this lot, so I might already have the part number!
Name of the Supplier. INERGY
Equipment part number. 98 002 020 80
Equipment additional reference. 98 002 020 80
Part number of the additive reservoir. 40 656 03A 0A
Messaging index. B
Thanks as usual :)
Afternoon all,
Think I might have been missed as quite a few requests came through together. Can you confirm what I need in terms of DPF additive please?
Thanks,
Matt
x 6946
Hi Matt - oops, sorry about that, must have missed your post.
You have a reservoir tank, not a pouch system, and require Powerflex additive.
Top up 1 litre minimum, official capacity is 1.4L, but shows actual is 2.0l.
Item (16) here: part number is: 1610115580.
x 2361
Spot on, thanks a lot Marc! :)
moizeau
x 423
Unread post by moizeau »
Hi Marc, could you confirm the part number for a front ABS sensor on my 407 please? I've got 4545A9, 4545G6 and 9642687580.
Cheers
Pete
x 6946
Neither! (only one part is correct, but that's an old part and superseded now Pete).
(1) Front ABS Sensor, part: 4545K6, £93.53
moizeau
x 423
Thanks, I'm old enough to be superseded
Pete
cs101
x 6
Unread post by cs101 »
GiveMeABreak wrote: 12 Aug 2024, 19:59 Image
(8) Headlamp Cap, part: 1614312480, £28.12 (this may be for both, so would need to confirm).
Let me know which item from the following you need:
Thanks Marc, I need number 2 please. Are number 3 and 4 attached to number 2 ?
x 6946
(2) Air Deflector Under Engine, part: 9820189780, £114.85
Please note that items (3, 4, 5 & 6) are not showing as fitted to your van and therefore not listed. :wink:
Daibach
x 4
Unread post by Daibach »
Hi Marc, could you provide part no. for radiator fan relay for my C4 please. Fan does not fire up at all, so I'm guessing that's what I need. The fan spins freely, so is there any easy way I can get power to it to check out the motor? My vin is VF7**************[VIN obfuscated, can be read by forum staff]. Thanks once again.
