- x 8437
- x 5678
It's tripped and fallen over
- x 8437
- x 2367
Ha ha, I've more than learnt my lesson there! Quite light stuff but the trailer itself is a heavy lump!
But more trailer action, my little trailer is lined up for an airport trip next week, so I thought I'd test the lights as it's not been anywhere for I think a couple of years!
All but left rear sidelight working. Which actually turned out to be miraculous frankly!
Trailer lamp cluster stripped down, very, very corroded spade terminals found.
- x 2367
- x 8437
Looks like it's been out at sea for a few years Matt!
- x 3565
I think all trailer lamps and electrics are made out of a very special fast dissolving metal as they always end up like that
- x 2367
Yes, seems so!bobins wrote: 11 Aug 2024, 18:06 I think all trailer lamps and electrics are made out of a very special fast dissolving metal as they always end up like that![]()
Also every trailer lamp cluster I've come across seems incapable of keeping the water out. A tide mark at the bottom pretty much standard!
Yes Jim, if it was a boat trailer I'd probably say "fair enough, that's to be expected dunking it each launch!" But it's definitely only done land based things with me!!
- x 2367
Cored the cables bit further up and it's usual black, oxidised, horrible mess. So currently dunked in vinegar to try and find something copper coloured!
Fixings of new socket copper greased.
Heat shrinked the two cables (Erde / Daxara = cable from each lamp cluster all the way to the socket) together and another larger piece to shrink over the new socket's rubber end seal.
Whether it keeps the water out or just gives additional hurdles next time it fails...
...TBC!
...TBC!
- x 8155
I used to have the same problem on an annual basis with the boat trailer but in the end I found a method which lasted from its inception to the point of sale which was about 6 years. I encased each loom in bicycle inner tubing sealed at the connections with self amalgamating tape applied correctly as I was taught in the GPO. Once done no further failures occurred at all!
- x 2367
- x 2367
All back together and....
Brake lights= functional both sides.
Tail light = still dead, left rear.
Indicators = right: faultless, left: comes on sporadically with percussive maintenance.
So a step backwards basically!!
I remembered that Daxara / Erde in their wisdom include an additional bonus moisture ingress point, I mean electrical connection, behind each tail light (or in other words roughly inline for a good deal of spray from the trailer wheels)
Funnily enough this does not look great.
And percussive maintenance has cracked (or alerted me that it was already cracked) the lens of the uncooperative tail light too.
So, off to Amazon / eBay and I'll change the lot.
- x 2367
Not stated, but bulbs checked obviously! (Multimeter on Continuity mode with help from my 5 year old who enjoyed manipulating the probes and triggered the meter to beep!
- x 2367
£40.86 has got me two full sets of LED tail lights, each with 10m cabling (so about 7 metres spare worth cutting off) and new sockets. So both small trailers can be fixed (it was the other small one's lighting which was playing up last time - though not pre-wired Erde nonsense there. That is a "Franc" trailer)
If arrives by Thursday I could potentially get that fitted ahead of the Friday Airport Trip as planned. Can fall back in my magnetic set as a backup plan.
- x 2367
Odd: Two lots of £20.42 doesn't equal £40.86 but that's what I paid.
WHERE'S MY 2p GONE EBAY!?
