- x 6956
No worries:
(1) Left Driveshaft
OEM New, part: 9675025880, £524.69
Exchange, part: 1609610380, £315.02
(2) Right Driveshaft
OEM New, part: 9675025780, £524.69
Exchange, part: 1609609380, £315.02
(1) Left Driveshaft
- x 6956
As far as I can tell - that's the French for the same colour (Black Pearl).trollkarlen wrote: 09 Aug 2024, 13:14I called Peugeot and they have the color on the roof listed as "NOIR PERLA NERA"GiveMeABreak wrote: 08 Aug 2024, 10:03 Your Body Colour Code is: KWE - PEARLESCENT WHITE PAINT.
Roof: Black Pearl Roof (no colour code as these are not painted, but manufactured plastic).
So the roof is all plastic?
I have a hole though the roof thats needs fixing, its from cable to lightramp that was installed by the previous owner. So plastic that makes it a little more difficult for me![]()
I suspect it's plastic, but you can check when you're in for t he other work at the dealer.
Rhothgar
- (Donor 2026)
- x 221
Afternoon Marc,
Hope you’re well and having a great weekend.
Could I have a part number please for either the reluctor ring or, if NFP, the rear near side brake disc for the 3008 please?
I’ll post separately in the telematics section regarding the specification of what the car has.
- x 6956
No problem, they're not sold separately, so here are the Disc parts (note these are only sold in pairs as must be fitted in pairs when replacing as I'm sure you know already):
(1) Wheel Hub Disc, OEM Original, part: 424946, £158.14 x 2 = £316.28
Cheaper alternative, part: 1619238880, £104.60 x 2 = £209.20
As you can see they contain the disc, hub, ABS ring, bearing and nut as a kit.
Rhothgar
- (Donor 2026)
- x 221
Daibach
- x 4
Hi Marc, part no. please for aircon HP switch on my C4 hatch. Vin No. VF7**************[VIN obfuscated, can be read by forum staff]. Thank you sir.
- x 1485
Item 20?
9833078680 (replaces 6455CK). £64.48
Mexico14
Is that the gasket between the cooler and the oil filter? Apparently theres 2 different ones.GiveMeABreak wrote: 09 Aug 2024, 11:06
(5) Engine Oil Filter Body Seal, part: 9804281880, £54.62
(7) Seal, part: 9804338480, £33.01
Daibach
- x 4
Thanks Richard. Item 20 it is.Regards,
- x 6956
I've provided both the gaskets - depends what you want as they are different.Mexico14 wrote: 12 Aug 2024, 11:46Is that the gasket between the cooler and the oil filter? Apparently theres 2 different ones.GiveMeABreak wrote: 09 Aug 2024, 11:06
(7) is the seal for the engine oil-water distribution changer
(5) is for the body seal for the Oil Filter.
cs101
- x 6
Please can I have the part number of Headlight dust cover caps for my Peugeot Expert van .
Also the sump guard plate which protects the engine sump.
- x 6956
(8) Headlamp Cap, part: 1614312480, £28.12 (this may be for both, so would need to confirm).
Let me know which item from the following you need:
- x 2337
Good evening,
Could you confirm the quantity ** / type of Eolys DPF fluid for the blue 308 SW (vin VF3**************[VIN obfuscated, can be read by forum staff] ) it tells me it's got zero Milliliters left!
If there's a picture of the tank or squidgy pouch thing approximate location that'd be fantastic too,
DiagBox suggests 1.35 litres,
It also stated all this lot, so I might already have the part number!
Thanks as usualName of the Supplier. INERGY
Equipment part number. 98 002 020 80
Equipment additional reference. 98 002 020 80
Part number of the additive reservoir. 40 656 03A 0A
Messaging index. B
Rhothgar
- (Donor 2026)
- x 221
Seems like I've opened the floodgates on this 3008...
Could I have the part number(s) for the rear shock absorber gaiters and bump stop (if separate) please? I imagine handing doesn't matter looking at them but it's the nearside if it does.
Thanks, as ever, in advance, Marc.
- x 6956
(5) Protector Bump Stop, part: 525442, £67.10
However it would seem. according to the diagram. the a complete new shock would come with that for a few £ more....
(1) OEM Rear Shock, part: 5206RT, £92.88
Cheaper Rear Damper, part: 1623318980, £73.97
