Hello.
I have a 2017 model Toyota Proace , wich i understand is the same as Citroen Berlingo/ Dispatch.
I am looking for wiring diagram for the DPF system.
Anyone know where i can get this ?
Wiring for 2017 model Proace(Dispatch?)
- x 6950
Re: Wiring for 2017 model Proace(Dispatch?)
Sorry, diagrams are vehicle, engine, build date and system-specific. I can't help you with non-PSA vehicles, regardless of whether there are some similarities and I wouldn't have one for this year in any case. Best off asking on a Toyota / Proace Forum.
Proace7000
Ok.. i Have been told that this car is a PSA car with Toyota badge on, from several sources
Proace7000
Found this link, about Toyota/PSA
https://www.autocar.co.uk/car-news/new- ... fca-merger
The cars look the same
- x 1955
I think that the problem is that the Proace will have a VIN identifying it as a Toyota and this is not recognised by the (chargeable) PSA part look-up system.
- x 6950
Apart from that, 'collaboration' vehicles which include the Citroen C1, Peugeot 107 which are essentially Toyota Aygos as one example may share components, but each can be fitted with either PSA engines or Toyota engines and parts.
It's the same with the Fiat Ducato, which was built with cooperation with PSA, so you have the Jumper, Relay & Boxer variants. Again the same with Ford. These can have Ford or PSA engines - and equipment can be Ford, Fiat or PSA variants.
