Main airbag warning light
Tinnie
Unread post by Tinnie »
My car is a 2001 Xantia HDI 110, recently the main airbag warning light goes out as normal, then comes within a few seconds and starts slowly blinking.
According to Citroen handbook, if a fault develops with the main airbag the warning light flashes fro 5 seconds, then remains alight.
I have had previous problems with the seat airbag warning which failed to out, this has always been resolved by squeezing the connector under the passenger seat.
Can anyone help me to locate where the connectors for the main airbag are?
P.S Can anyone recommend a good manual for the above car?
Thanks -
Tinnie
dean36014
x 8
Unread post by dean36014 »
Had the same problem with mine, light permermantly flashing. Turned out to be the connectors under the drivers seat this time for the seatbelt pre tensioners. Quick clean and spray with wd40 and problem solved.
alexx
Unread post by alexx »
I had the same problem. Temporary resolved by plugging a resistor into the connector as a "dummy air-bag" and left that way so far ...
Here are some pictures ...
http://www.citroenbilten.com/forum/view ... p?tid=3911
