x 6945
On the first vehicle, there's no 5134G4 part number listed at all Matt. Here are the 2 diagrams referring to the rear torsion bar and hub, - but note on the Torsion bar diagram there is no item (3) listed for this vehicle. Let me know the item(s) from the relevant diagram.
Rear Torion Bar
Rear Hub
Heat Shield
The only Heat Shields present for the exhaust system are those shown (except for a small one on the catalytic converter / DPF Assembly).
Second Vehicle
Aerial
Notes:
(5) Tailgate washer pipe includes an aerial harness in the assembly.
(20) Aerial Amp is for AM / FM1
(21) Aerial Amp is for FM2
FM2 Aerial is imprinted onto the rear screen.
If fitted with DAB, the aerial is 'J'
Towing
There is a specific Electrical Harness showing for this vehicle with your build date (others are not compatible), so: TOW BAR WIRING LOOM 13-TRACK, part: 1611864380, £209.23 should be correct.
Comes with a 13 way socket, and Generic Trailer Relay Unit
Features:
  • This harness is particularly suitable for providing the lighting supply to trailers or cycle-carriers on tow bars.
  • This harness has been developed to incorporate all of the vehicle special features.
  • It also provides an electrical supply to the fog lights and reversing lights.
  • Comes with a 13-way socket to correspond to the trailer socket.
  • It incorporates all the features needed for good compatibility with this vehicle and is SAFE, RELIABLE and EASY to fit.
  • In addition to deactivation of the parking aid when the vehicle is towing, this wiring loom incorporates the blown bulb detection function.
  • The functionality of the harness will be obtained by configuration of the BSI (fitting by the network is imperative).
This is the only toolbar listed for the vehicle with this wiring harness:
1608472480: SWAN’S NECK TOWING BALL, £239.38
x 6945
GORAX wrote: 29 Jul 2024, 10:43 Hi,
Where exactly is the cabin filter located? I want to change him.
Item (6)
x 2356
Unread post by MattBLancs »
GiveMeABreak wrote: 29 Jul 2024, 10:58 On the first vehicle, there's no 5134G4 part number listed at all Matt. Here are the 2 diagrams referring to the rear torsion bar and hub, - but note on the Torsion bar diagram there is no item (3) listed for this vehicle. Let me know the item(s) from the relevant diagram.
Rear Torion Bar
How odd, it's definitely number 3 I need!
Second Vehicle
Towing
Aerial information: excellent thank you.
Towbar wiring and kit: excellent thank you. Surprisingly non-eye watering!
Thanks very much! :)
x 6945
Ok, I see what they've done Matt - on this variation, it is part of the complete assembly, so shown as (1) which includes 'A' & (3)
(1) Rear Crossmember Assembly, part: 5148R7 (No Longer Available from Peugeot), was £1015.75 new. :(
Your Estate Leisure vehicle is designated as having 'Heavy Duty' suspension, so that is likely why it is a complete assembly.
x 2356
GiveMeABreak wrote: 29 Jul 2024, 14:36
Now, that's more eye watering! :rofl2: (though not available) Autodoc had the axle or rather a compatible one from that part number (5144r7) of QH brand, but out of stock but a more comfortable £311.44.
I'll not dilute this thread any further, so will continue my thinking aloud back in my blog thread.
Thanks again for digging.
Thanks also for the expanded view as it's answered two other questions!
(What 11 is? = A vibration damper)
(Should I have the (plastic, aerodynamic?) bits number 14 & 15, under the two spring cups = nope, not listed so not "missing" as I thought!)
x 6945
If you mean (13) & (14) (not (15)), then no, you don't have these either :wink:
Huskyxantia
x 920
Unread post by Huskyxantia »
Hi Marc , Is there a part number for the steering gaitor clips 308cc my vin
VF3**************[VIN obfuscated, can be read by forum staff] im considering letting a local garage just nip the clip back up theres no way i can do it on the ground its beat me lol , thanks for the part numbers if there is any.
:-D
x 6945
(4) Steering Gaiter Kit, part: 406682, £34.49
Huskyxantia
x 920
Cheers Marc your a life saver
:-D
GORAX
x 14
Unread post by GORAX »
Hi :)
I noticed that the lighting is missing on this piece. Where can I find this? The part is below the glove compartment
GOOGLE TRANSLATE
x 1492
Appears it was never fitted to your car (part number not showing against your VIN):
Part number if 6362N6 - if the cable is there you could get one from a scrap car - or from the dealer - in the UK it's only £6.53
GORAX
x 14
What kind of connection does it have? CAN BUS?
GOOGLE TRANSLATE
x 1492
No, just a 2 wire power and earth.
cs101
x 6
Unread post by cs101 »
Hi! Please can I have part number of Alternator of my Peugeot Expert van please with separate part number of its Pulley.
Also the part number of Under Bonnet Sound insulation cover please.
x 6945
(1) Alternator:
OEM Original, part: 9810525380, £1010.50
Exchange, part: 1612458880, £635.96
(4) Pulley, part: 1611503780, £64.02
(60) Pulley, part: 1622780280, £165.95
(15) Bonnet Sound Proofing, part: 9808644380, £157.55
