508c5
- x 4
C5 Aircross 2019 (180HP petrol) - filters car parts
Hello,
I was wondering if you guys can help with the following filters parts:
Oil filter,
Air filter
Interior cabin air filter
Thank you
Oil filter,
Air filter
Thank you
Reason: Moved to parts thread (please use this thread for official parts requests)
- x 6957
@508c5: Please request official parts on this thread.
Oil Filter
Oil Filter (inc. seal), OEM part: 9818914980, £18.29
Cheaper PSA filter, part: 1629084080, £10.36
Air Filter
OEM Air Filter, part: 1444TT, £35.74
Cheaper PSA Air Filter, part: 1611891680, £17.82
Cabin Filters:
Carbon (Particles & Gas), part: 6479K9, £53.42
Anti Allergenic (Premium High Performance Carbon), part: 1616959380, £66.78
Cheaper PSA Filter, part: 1609695780, £19.31
Oil Filter
Air Filter
Cabin Filters:
Stijn
- x 3
Hi Mark:
I meant the seals mounted on the car ( schoulder always rubs against it when getting out of the car) , not the ones mounted on the door.
On the picture with the engine support i need the part number of number 1
Since it is dying on me and autodoc is not clear i could use the part number of the starter motor as well.
Sorry for the mis understanding
- x 6957
@Stijn: This is called the Door Entry Seal
(6) Front, part: 9025E5, £134.95
(7) Rear, part: 9025E6, £134.95
Engine Mounting
The part is called an Anti-Torque link.
(1) Anti-Torque Link (Right), part: 1806H4, £125.05
Starter Motor
(1) Starter Motor, New Valeo OEM Original, part: 5802AW, £827.45
PSA Standard Exchange Starter, part: 1638126880, £184.01
Valeo Exchange Starter, part: 5802CA, £376.98
Engine Mounting
Starter Motor
GORAX
- x 14
Hi together,
Where exactly can I find the Keyless go antenna in the car and what is the part number?
GOOGLE TRANSLATE
Bryonyolney
Hi Chaps
Hadn’t quite expected to be back so soon but sadly I had an OBD fault with my turbo on my Citroen Relay crop up yesterday. Looking like it is the actuator (fully electrical 4 pin by the looks).
So can I please ask for a part number for the actuator for VIN VF7**************[VIN obfuscated, can be read by forum staff].
If there’s anynother part numbers related to a faulty actuator that you think it would be worth knowing about do let me know!
Thanks for your help
Bryony
Bryony
- x 6957
To be clear, you only have Hands-Free Starting, not Hands-Free Access, so in your case there is no antenna. You only have an key reader module built into the dash.GORAX wrote: 21 Jul 2024, 20:18 Hi together,
(1) Electronic Key Reader, part: 9800630080.
Remember, you can't just replace these with another unit. It must be coded via server access.
- x 6957
Not shown separately....Bryonyolney wrote: 22 Jul 2024, 10:20 Hi Chaps
Bryony
Bryonyolney
@givemeabreak hmmm does that mean technically it isn’t a part you can buy separately from the main Turbo part according to the diagrams?
- x 6957
It's not available from PSA, whether you can purchase it elsewhere I can't confirm, but certainly not available from Citroen.
Here are the part numbers for the turbo for you in any case.
(1) New Borg Warner Turbo, part: 9841634380, £2175.50
Exchange Borg Warner Turbo, part: 1679597380, £1356.84
admiral51
- (Donor 2026)
- x 391
Hi Marc,
Looking for some information on a Citroen C1 Drivers door electric window switch/motor. Its my niece's car and all i can get so far is the Reg HN66FNZ ( taken 2 days to get that
). VIN is proving to be a problem
I have learnt that the passenger window works from the drivers side and that there maybe a click or some noise when the drivers window button is pressed. I know it is not really a Citroen but can you get any info from just the Reg.
thanks in advance
Colin
thanks in advance
Colin
dave101ua
Hello Mark!GiveMeABreak wrote: 05 Jul 2024, 19:01dave101ua wrote: 05 Jul 2024, 07:08 Hello !
Could you please tell me part number for timing belt ?
which parts are usually replaced together with timing belt ? I need those ones too
Thanks in advance !
VIN is : VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
(18) Timing Kit including Coolant Pump and Rollers, part: 1610278280, £356.95
Could you please tell me part number for the chain which is shown on picture ( Number 3) and also when it should be replaced ?
- x 6957
Can't help without the VIn Colin - PSA system don't use reg numbers.admiral51 wrote: 22 Jul 2024, 19:00 Hi Marc,
Looking for some information on a Citroen C1 Drivers door electric window switch/motor. Its my niece's car and all i can get so far is the Reg HN66FNZ ( taken 2 days to get that). VIN is proving to be a problem
thanks in advance
Colin
- x 6957
It's Marcdave101ua wrote: 24 Jul 2024, 17:42Hello Mark!
(3) Camshaft Timing Chain, part: 0816F6, £78.30
- x 5674
I think I looked for my granddaughter's VIN on her C1 and it isn't in the corner of the windscreen like most are.GiveMeABreak wrote: 24 Jul 2024, 20:06Can't help without the VIn Colin - PSA system don't use reg numbers.admiral51 wrote: 22 Jul 2024, 19:00 Hi Marc,
thanks in advance
Colin
