DS9 Non Phev poor/ noisy ride quality
DS9_
New User
Re: DS9 Non Phev poor/ noisy ride quality
Unread post by DS9_ »
Hi!
I have signed up to a DS9 - Performance Line PHEV lease - car was due to be delivered on 9th July and I had an email late on the 8th to advise a driver couldn’t be sourced therefore the delivery date was pushed back until today…
I was notified by the dealer that the car wouldn’t be delivered today as it had developed a fault - it wouldn’t start which had been picked up in the PDI centre…
I was further advised that I would be updated this afternoon in terms of when I could expect the fault to be rectified and when I could expect delivery..,
The car was built in 2022 and registered in 2023 so will have been stored in a depot for around 2yrs -so I suppose the battery issue may just be a case of it having declined as not been used.
Fast forward to now- the car has been recalled this afternoon and a new car, same spec etc has been sourced and the expected delivery date will now be 23rd July. Something seems a bit off here!
I wondered if anyone else has issues with the car starting, any recalls/ updates etc that rendered the car to be unfit for purpose?
This whole saga has got me feeling quite jittery to say the least!
Not only have I been massively inconvenienced as I need the car for work and have literally been begging colleagues for a ride into work and I’m now wondering just how reliable it will be and if trips to the garage are going to be a regular occurrence?
x 6950
The issues will very likely stem from 12V main service battery depletion. When this happens all related systems can be affected and even with the battery recharged it can still leave unresolved issues with the vehicle.
Technically, the PHEV should be able to run in ICE mode without charging the Traction battery, but if the car has been sat for a very extended period like the 2 years you mention and is totally without power, then this may have affected electrical ECUs like the engine ECU, the BSI and PHEV battery management systems - specifically that some settings may have been lost. I know these should be written to non-volatile memory storage that should not be affected with power withdrawal, so I can't say for sure. There are obvious problems after they tried to restore power to the vehicle you were going to have, but I suspect your replacement should be fine.
chrislon
Unread post by chrislon »
DS9_ wrote: 16 Jul 2024, 17:33 Hi!
Hi,
I have just got a DS9 Performance Line PHEV lease - car , almost certainly from the same batch as yours as I believe they had a few, built in 22 and registered Sep 23. I got mine on the 20th June and have had zero issues with it. I've done about 700 miles so far.
I had to update the touchscreen and satnav firmware and there was a delay in getting the connected services activated, but the car itself has been fine. No starting issues, a reported 34 mile range on battery (25 - 28 in reality). I've done a couple of longish 100+ mile trips in hybrid no problem and loads of short trips on battery only.
Hopefully yours is a one off and the new car will be fine.
DS9
x 34
Unread post by DS9 »
I had issues with my car in a roundabout way similar to what's been mentioned.
Although mine aint the PHEV, and I got it 13 months old with 100 miles on the clock I found out after owning for about 9 months that the battery had been changed but not to a SS version, so I replaced myself. I think it's typical that with cars stood for so long that the battery gives up. Fine now.
I have done more soundproofing behind the front wheel well plastic liners, dodmat first and then closed cell foam on top, seems a bit better but still can't totally get rid of a clunking/ knocking sound from the front passenger side, not sure what it is. might be something loose underneath that side. I put loads in, so much so it wasnt easy fitting it all back.
One question for givemeabreak just to double check something. my plate on the passenger door gives a code EPH and I presume that's the paint code. have you got any suggestions for touch up paint as there is allsorts out there and I could do with a paint pen or similar.
x 6950
Hi, yes, that's correct,:-
EPH = CHRYSTAL PEARL PAINT
x 6950
Let me know if you require your Factory Build Sheet.
DS9
x 34
Hi
Thanks for the offer. I suppose that may be helpful to see the build sheet if you can get me one. I'm not expecting any surprises on there as it seems standard spec.
x 6950
Here you go:
Vehicle Characteristics
Vehicle familyDS 9 (X83)
AS/RP N°16293 UE 2 0004
Warranty Start Date30/06/2022
Engine Serial Number10 UE59 6001415
OPB00LV
BERe2*2007/46*0718*02
P4A9833572699
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPEDS
VEHICLE FAMILYDS 9 (X83)
SILHOUETTE4-DOOR SALOON
TRIM LEVELMEDIUM HIGH
ENGINEEP6FADTX/EU63 1598 PETROL
TRANSMISSIONSTT TYPE 8-SPEED AUTOMATIC GEARBOX
PAINT TYPEPAINTED METALLIC EXT TRIM TYPE
BODY COLOUREPH - CHRYSTAL PEARL PAINT
INTERIOR TRIM TYPEMIXED LEATHER "56"
UPHOLSTERY COLOUR"FV"
ENGINE (TYPE)EP TYPE ENGINE
ROOF (EXT. ASPECT)ONYX BLACK ROOF
PRE-EQUIPMENT FOR CONVERSIONWITHOUT PRE-EQUIPMENT FOR CONVERSION
OTHER BADGE, " MISC. "GT SPIRIT
BADGEFAMILY BADGE
Fuel Supply-Engine
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
FUELUNLEADED PETROL 95 QUALITY A/B/E/E+
EMISSIONS STANDARD (ENGINE)EURO 6.3 ENGINE EMISSION CONTROL
CAPACITY1600 CM3
FUEL TANKFUEL TANK WITHOUT LOCATING TAB
COOLING MOTORRADIATOR 28DM2 - EP28 SEMI SURFACE
SPECIAL POWER TRAIN SOUNDWITHOUT POWER TRAIN ACOUSTICS
EOBD SELF-DIAGNOSIS SYSTEMWITH "OBD" AUTO-DIAGNOSTICS
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
FAN1ELECT VARIABLE SPEED 180W AERO DYNAMIC FLAP
DRIVE TRAININTERNAL COMBUSTION DRIVE TRAIN
TANK FILTERRESERVOIR FILTER INTERIOR
STOP AND STARTWITH STOP AND START STARTER
Gearbox Transmission
WHEEL STYLE19-INCH MUGIWARA
RIM/TYRE SIZE19 INCH TYRE FIT
TYRE (SIZE, TYPE)235/45 R19 99Y REINFORCED TYRE
DRIVING WHEELS2 DRIVEN WHEELS
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 1
GEARBOX TYPEATN8 TYPE GEARBOX
Suspension-Steering-Brakes
REAR ANTI-ROLL BARANTI-ROLL BAR DIAM 19
FRONT ANTI-ROLL BARFR ANTI-ROLL BAR STIFFNESS 32500 NM/RAD
BRAKE TYPEVENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLEWITH STEERING ANGLE SENSOR
SUSPENSIONNORMAL SUSPENSION
BRAKE ASSOCIATED VARIANTESP BOSCH 9.1
STEERING (OPERATION)LOW POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE)PEDAL ALUMINIUM
Body Fittings
TOWBARTRAILER PRE-EQUIPMENT
SIDE MOULDINGS (DIMENSION)WIDE SIDE PROTECTORS + LIT SILL
UNDERBODY SHIELDDEFLECTOR UNDER FRONT FLOOR
SIDE REPEATER INDICATORSSIDE LIGHTS
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTIONDRIVER+PASSENGER+DIODE+REVERSE ELECTRIC FOLDING MIRROR
WINDSCREEN GLASS (TYPE)STANDARD WINDSCREEN GLASS
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
BUMPERFRONT BUMPER+WINGS CH/REAR BUMPER+SKIRT BODY COLOUR
FRONT FOGLAMPLED FRONT FOGLAMPS
PANORAMIC VISUAL AIDWITH REAR PANORAMIC VISUAL ASSISTANCE VISIO PARK1
SPARE WHEELWITHOUT SPARE WHEEL
SUN ROOFWITHOUT SUN ROOF
GLASS (APPEARANCE)TINTED + DARK-TINTED WINDOW GLASS
HANDS FREE ACCESS AND STARTINGFRONT ACCESS+BOOT+CONTACTLESS STARTING
Interior Fittings
ANTI-THEFT ALARMVOLUME + PERIMETER + LIFT
CIGAR LIGHTERWITHOUT CIGAR-LIGHTER
FRONT HEAD RESTRAINT4-WAY ADJUSTABLE FRONT HEAD RESTRAINT
REAR SEATSEPARATE FOLD BACK BENCH SEAT
BLIND SPOT DETECTIONWITH BLIND SPOT MONITORING
CLIMATE (AMBIENT TEMP)HOT OR WIDER TEMPERATE COUNTRY
AIR CONDITIONINGWITH HEATER MATRIX WITHOUT RECIRCULATION
DRIVING POSITIONRIGHT HAND DRIVE
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
MIRROR LINKWITH MIRROR LINK
BOOT AND LOAD SPACE LIGHTINGBOOT+LOADING VOLUME 2LEDS AUTO LIGHTING CONTROL
DASHBOARD EQUIPMENTALCANTARA DECOR DASHBOARD
MISC. INT. LAMPSMONOCHROME AMBIENCE LED LIGHTING
INSTRUMENT PANEL (CHARACTERISTICS)DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS
CHILD SEAT ANCHORING POINTSWITH CHILD SEAT MOUNTING WITH ISO FR AND RR
LOUDSPEAKER4 HP FRONT (2 TW + FR) + 4 HP REAR
ADDITIONAL BLOWERWITHOUT ADDITIONAL PULSE
POLLEN FILTERWITH POLLEN FILTER + ACTIVATED CARBON
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF)WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROLFRONT PASSENGER SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT+ELECTRIC FRONT SEAT CUSHION ANGLE
DRIVER SEAT CONTROLDRIVER’S SEAT WITH MEMORY CONTROL+CUSHION FRONT ADJUSTMENT
FRONT PASSENGER SEAT CONTROLPASSENGER’S FR ELEC SEAT CTRL + CUSHION FRONT ADJ
DRIVER SEAT ADJUSTMENTDRIVER’S SEAT TILTING BACK ELECPNE LUMBAR SUPPORT+MEMO
FRONT PASSENGER SEAT ADJUSTMENTPASSENGER ELECTROPNEUMATIC LUMBAR ADJUSTMENT
SATELLITE NAVIGATION SYSTEMWITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBSLED BULB
TRAFFIC INFORMATION READERPREVENTION+CORRECTION+DETECTION OF EDGE
DISPLAYDGT TOUCHSCREEN+12" DFT DISPLAY
CLOCKANALOGUE CLOCK
FOOTRESTALU DRIVER’S FOOTREST
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGFR CHEST/PELVIS SIDE AIRBAG+INT+FR/RR CURTAIN
EQUIPMENT PACKW/O EQUIPMENT PACK
EXTERIOR REAR VIEW MIRROR (HEATED)HEATED EXTERIOR MIRROR
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTERAUTOMATIC HEADLAMP ADJUSTMENT
WIFIWITHOUT WIFI
RADIO RECEIVERDIGITAL CONNECTED NAVIGATION
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLREGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROLELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRRORFRAMELESS INTERIOR ELECTROCHROMATIC MIRROR
AIR CON./TEMPERATURE REGULATIONAUTOMATIC AIR CONDITIONNED BI-ZONE
REAR SEAT PADDINGREAR PASSENGER DETECTION WITH PAD
OBSTACLE DETECTION SYSTEMFRONT-REAR RADAR OBSTACLE SENSOR
LATERAL BLINDSWITHOUT SIDE BLINDS
EQUALISER AMPLIFIERWITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCYWESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROLCENTRAL DEADLOCKING + AUTOMATIC LOCKING
STEERING WHEELPERFORATED LEATHER 4-SPOKE STEERING WHEEL
AUDIO PACK AUXILIARY SOCKET4 USB PORTS
TELEMATIC UNITINDEPENDENT TELEMATIC UNIT 3S
Electrical
ALTERNATORALTERNATOR CLASS 18 180 AMP
BATTERYBATTERY L3 760 VRLA2 EN AGM
ELECTRICAL EQUIPMENT (SUPPLY)JCI BATTERY EUROPE
BATTERY CHARGERWITHOUT ON-BOARD CHARGER
MULTIPLEXINGR3 ECO ELECTRICAL ARCHITECTURE
ELECTRIC VEHICLE CHARGING PLUGWITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENTWITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
MODIF. DURING MODEL YEARWITHOUT MINOR MODIFICATIONS
CONDENSER (SPECIFICATIONS)CONDENSER 28DM2 - THICKNESS 16 BCH SCREWED
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABELWITHOUT LABEL
AIR CONDITIONING PIPESIHX TECHNOLOGY AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKETWITH ACCESSORIES SOCKET
SIDE IMPACTSREINFORCED SIDE IMPACT PROTECTORS
SET OF KEYSSET OF BADGE KEYS + BACK-UP KEY
REFRIGERANTAIRCON FLUID 1234 YF
EMERGENCY EQUIPMENTPUNCTURE REPAIR KIT
SURFACE CONDITIONSGOOD TERRAIN
SPEED MONITORINGWITHOUT SPEED CHECK
DS9
x 34
Thanks for that, much appreciated.
