x 8428
Oh gosh Matt, that hub nut :shock:
It's not as if new hub nuts are expensive or hard to get... That's just sheer bodgery :twisted:
The only saving grace is that at least an attempt was made...
x 2366
Unread post by MattBLancs »
CitroJim wrote: 15 Jul 2024, 08:38 Oh gosh Matt, that hub nut :shock:
Not pretty is it!? :-D
Trying and failing to find new CV joints,
GSF, euro car parts, Halfords trade, J&R driveshafts (through eBay) = none listed.
I've emailed this seller to confirm suitability:
https://www.ebay.co.uk/itm/204040934395
AHH, they have just come back to me to confirm it isn't suitable and they can't get one from one of their suppliers either.
Which basically leaves this £76.53 option which looks rather different than any Peugeot drive shaft I've seen before:
From eBay ad
From eBay ad
https://www.ebay.co.uk/itm/335483282657
Oh wait, it's just an illustration rather than anything of any use!
Message to them to check shortly.
x 3565
The Parts In Motion offering is a NAPA parts piece so you could try a lookup on the NAPA site to see what they have to say.
https://www.napaautoparts.co.uk/
This is the compatibility from the P.I.M. website:
NAPA CV compatibility
x 1496
If you post up the VIN we can look up the Pug part no ( and price🤣🤬)
x 3565
Apologies for going off topic on your blog, Matt 8-[
A little bit of background info regarding NAPA.
Are you sitting comfortably ? Then I shall begin.
NAPA started in America about 100 years ago. They are owned by Genuine Parts Company https://www.genpt.com/
GENPT also own the Alliance Automotive Group.
The Alliance Automotive Group own a host of other garages and suppliers via, variously:
Groupauto https://groupauto.co.uk/our-group/member-directory/
United Aftermarket Network https://unitedaftermarket.net/our-netwo ... directory/
Alliance Automotive motor factors https://allianceautomotive.co.uk/our-network/
Apec Automotive (braking etc) https://apecautomotive.co.uk/
Tayna Batteries https://www.tayna.co.uk/
And quite a few others.
More info on The Alliance Automotive Group and their subsidiaries..... https://allianceautomotivegroup.eu/our- ... d-kingdom/
Edit..... What a surprise, Alliance Automotive Group acquired Parts In Motion earlier this year.
https://allianceautomotive.co.uk/news/a ... rslimited/
It's a small world, etc, etc. :roll:
And in further motor factor related news - Eurocarparts and GSF are owned by the same company, namely LKQ. :shock:
https://www.motortrader.com/motor-trade ... 03-03-2023
x 2366
RichardW wrote: 15 Jul 2024, 19:35 If you post up the VIN we can look up the Pug part no ( and price🤣🤬)
Had a quick look on the "parts Asia" site and think it's the full driveshaft from Peugeot, for extra eye watering -ness!
Will get the VIN when I'm back home (down in Bristol as of about 15 minutes ago. Vauxhall Crossland hire car = not my cup of tea!) on Thursday.
I've asked Parts in Motion if they can confirm suitability based off reg number.
Interestingly that Napa website only seems to list the 308 SW 2.0 has 180 rather than 150. Autodoc does the same based on reg number. But is also quite convinced it's an automatic.
I thought the autos were 163 BHP, so I'm not sure where the 180 comes from!
x 2366
bobins wrote: 15 Jul 2024, 20:14 Apologies for going off topic on your blog, Matt 8-[
No problem at all, like a good "side topic" branching off from the main trunk of my, err, waffling! :-D
x 2366
bobins wrote: 15 Jul 2024, 19:28 ... try a lookup on the NAPA site to see what they have to say.
Another dead end unfortunately!!
Nowt found!
Nowt found!
x 2366
For your entertainment, here's another "analogue spreadsheet" - this one my thinking behind the wheel choice for 308,
Wheels: sizes, offsets and tyres: diameter differences and quick price/availablity trawl (from black circles)
Oh, reminds me, one new rim on order:
Rim
Rim
£43.32 with a discount code. Should arrive at home before I do!
x 2366
SKF website:
https://vehicleaftermarket.skf.com/ie/e ... Driveshaft
Lists:
Drive Shaft
VKJC 8876
Criteria for this product to fit
PEUGEOT 308 SW II (LC_, LJ_, LR_, LX_, L4_)
Front Axle Right
Transmission Code: ML6C
Transmission Code: AT6 3, ATN8
Article Information
Length: 919 mm
Thread Size: M22x1,5
External Toothing wheel side: 28
External Toothing differential side: 37
Seal Diameter: 58,5 mm
Length 2: 277 mm
Supplementary Article/Info 2: with bearing
Wheel-side joint diameter: 84,4 mm
Transmission-sided joint diameter: 80 mm
And
Drive Shaft
VKJC 8897
product
Front Axle Left
Transmission Code: MB6
Article Information
Length: 680 mm
External Toothing differential side: 24
Length 2: 61,5 mm
New Part
And this, Auto only:
Drive Shaft
VKJC 8875
Front Axle Left
Transmission Code: ATN8, AT6 3
Article Information
Length: 642 mm
Length 2: 59 mm
And this:
Drive Shaft
VKJC 8871
Front Axle Left
Article Information
Length: 650 mm
Seal Diameter: 58,4 mm
Length 2: 68,5 mm
Wheel-side joint diameter: 94,9 mm
Transmission-sided joint diameter: 87 mm
And finally, this:
Drive Shaft
VKJC 8925
product
Front Axle Right
Article Information
Length: 920 mm
Length 2: 277 mm
New Part
Transmission-sided joint diameter: 82 mm
And for completeness a bunch of CV boots:
Spoiler: show
logo
car-icon
Find the part you are looking for
Filter spare parts for
Reset allRESET ALL
FILTER (2)
Viewing 5 of 5 products
Highlight differences
Bellow Set, drive shaft
VKJP 8353
product
Front Axle, transmission sided
Article Information
Thickness: 12 mm
Height: 97 mm
Outer Diameter 1: 72 mm
Outer Diameter 2: 82 mm
Inner Diameter 1: 25,5 mm
Inner Diameter 2: 69 mm
VKJP 01001 S
product
Front Axle, Wheel Side
Article Information
Height: 146 mm
Supplementary Article/Info 2: with clamps
Inner Diameter 1: 22 mm
Inner Diameter 2: 86 mm
VKJP 1311
product
Article Information
Height: 110 mm
Outer Diameter 1: 82 mm
Outer Diameter 2: 83 mm
Inner Diameter 1: 29 mm
Inner Diameter 2: 93 mm
VKJP 1421
product
Article Information
Height: 112 mm
Inner Diameter 2: 84,5 mm
VKJP 01001
product
Article Information
Height: 146 mm
x 2366
Autodoc list the auto only driveshaft:
Vkjc8875
https://m.autodoc.co.uk/skf/17224120
Manual driveshaft vkjc8925 (long shaft)
https://m.autodoc.co.uk/skf/15090337
Manual, short shaft vkjc 8897
https://m.autodoc.co.uk/skf/15090336
Manual, short driveshaft vkjc 8871
https://m.autodoc.co.uk/skf/17224119
Manual/ auto shaft vkjc 8876
https://m.autodoc.co.uk/skf/17224121
I'll have to get the VIN on the parts request page as requested recommended then hopefully I can see the wood for the trees!
x 2366
Very few list a CV joint alone that is definitely manual gearbox fitment, e.g. Autodoc:
CV joints on Autodoc
moizeau
x 423
Unread post by moizeau »
Not sure of the measurements or even if I've got the right car but.... this seems to show manual and auto https://www.piecesauto24.com/peugeot/30 ... otules-jeu
Pete
x 2366
moizeau wrote: 17 Jul 2024, 07:21 Not sure of the measurements or even if I've got the right car but.... this seems to show manual and auto https://www.piecesauto24.com/peugeot/30 ... otules-jeu
Thank you for digging, interesting that gives different results as seems to be another variant of the Autodoc company(s!!)
Wheel did race me home, I've heard it's landed today.
Parcel shelf bought (£80, delivered)
moizeau
x 423
Although it is a french website, all parts come from Germany in Autodoc boxes. I've been using them for a good few years
Pete
