x 1456
High and low use the same valve seemingly:
£37.10 each from Citroen.
seanrx
x 6
Unread post by seanrx »
Hi. Vin. VF7**************[VIN obfuscated, can be read by forum staff]
A number request please for a suspension fluid pipe, offside rear.
And a power steering pipe/hose. Nearside front. (To oil cooler).
The brackets are as printed on my MOT cert today.
But at least my front shock hasn't failed yet!
Thanks very much.
NorfolkVroom
x 5
Unread post by NorfolkVroom »
Hi, could I get the parts number for the oil filter, and air filter, on a MK1 Peugeot 3008 (1.6 eHDi 2014) please?
Daibach
x 4
Unread post by Daibach »
Hi Marc, Can you help with part no. for aircon compressor for my C4. I think you have the VIN no. on file, but I don't know how long you keep them. Also can you advise if this compressor has a clutch or is clutchless please ( I hope the latter cos I can't hear a click when I switch on aircon. Thanks once again ( or Diolch if you prefer)
danlat1415
x 24
Unread post by danlat1415 »
Please could you check the part number for Turbo Value Solenoid for VF7**************[VIN obfuscated, can be read by forum staff]
I'm seeing part number 1618PE but want to check if it's correct or been superceded.
x 1456
seanrx wrote: 12 Jul 2024, 17:29 Hi. Vin.
Thanks very much.
Suspension pipe - No 6?
PAS pipe - No 2?
Both are NFP. They were £26.52 and £97.13 respectively when they were available.
x 1456
NorfolkVroom wrote: 12 Jul 2024, 17:38 Hi, could I get the parts number for the oil filter, and air filter, on a MK1 Peugeot 3008 (1.6 eHDi 2014) please?
VIN:
Oil filter originally 1109Z5 now 1109 AY @ £18.54
Air filter 1444TV @ £35.74
x 1456
Daibach wrote: 12 Jul 2024, 20:48 Hi Marc, Can you help with part no. for aircon compressor for my C4. I think you have the VIN no. on file, but I don't know how long you keep them. Also can you advise if this compressor has a clutch or is clutchless please ( I hope the latter cos I can't hear a click when I switch on aircon. Thanks once again ( or Diolch if you prefer)
If you post the VIN I will check.
x 1456
danlat1415 wrote: 12 Jul 2024, 21:21 Please could you check the part number for Turbo Value Solenoid for
1618PE is right, no replacement part no.
Daibach
x 4
VIN is VF7**************[VIN obfuscated, can be read by forum staff]
x 6961
(1) New OEM Denso Compressor (DENSO THERM SYS 5SEL12), part: 9822101380, £ 1070.30
Standard Denso Exchange Compressor (DENSO THERM SYS 5SEL12), part: 1622731080, £574.55
Although not specified, I believe this has a magnetic clutch.
(There's a Denso one here: https://www.autodoc.co.uk/denso/11010131 for a lot less).
jakuboz
Unread post by jakuboz »
Hi, me again
Can I please have the part number for the selected rubber hose, plastic flange and its seal? And maybe also the hose that is not present in the photo but attaches to this plastic tee.
The image is from 206 engine, but location is similar/identical.
pugpirate
Unread post by pugpirate »
Hi Guys.
Part number for my catalytic converter please :-D
Reuben
x 6961
jakuboz wrote: 15 Jul 2024, 09:52 Hi, me again
You'll have to let me know if what you want is on any of the following, let me know the Diagram (A or B) and the item number.
Diag A Air Intake Manifold
Diag B Cooling Hoses
x 6961
pugpirate wrote: 15 Jul 2024, 10:12 Hi Guys.
Reuben
(11) Catalytic Converter:
OEM Original, part: 9800523680, £1328.68
PSA Cheaper Option, part: 1609435180, £1024.22
