pugpirate
That is awesome, thanks Marc
darbuck
- x 289
Hi Marc, Can you give me a part number for the seal on the turbo intake compressor side. It looks like a viton seal of some sort. It's for my C5 please?
Darren
- x 6946
Which Item?
darbuck
- x 289
Hi Marc, it's not shown in the drawing it attaches at the inlet above 15, it may be in the air intake drawings
Darren
- x 6946
(6) Turbo Air Side Union, part: 143484, £97.73
(7) Air Hose Seal, part: 143448, £8.35
darbuck
- x 289
It's number 7 thanks Marc
Darren
- x 6946
Got there in the end!
Skull
- (Donor 2026)
- x 382
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Xantia HDi Front Suspension lower arm ball joint dust protectors please
No 11 on previous page Marc's post @ 1.31pm
I think it's 96129349
Gary
Gary
- x 1496
It's 362306 - you'll not be surprised to hear it's NFP....
96129349 is not recognised.
Skull
- (Donor 2026)
- x 382
I see I have been confused by this part before
Gary
Gary
jakuboz
Hi Marc,
Can I have the part number for thermostat, and its seal/gasket (if it comes separately)?
Also, not to ask in a couple of weeks- I'll be fixing my rear beam, so I'll need part numbers for front/rear mounts, shock absorbers, and bump stops.
Thank you
Thank you
- x 6946
I already provided you with the front suspension parts here on 02/04/2024:
viewtopic.php?p=795673#p795673
NFP = No Longer Available from Peugeot
Thermostat
(11) Engine Coolant Thermostat, part: 113811, £54.06
(12) Seal, part: 134030 (NFP).
Rear Torsion
(1) Rear Suspension Crossmember, part: 514889, (NFP)
(3) Suspension Torsion Bar (Left), part: 515057 (NFP)
(4) Suspension Torsion Bar (Right), part: 515060 (NFP)
(9) RR Connection Socket, part: 513262 (NFP)
Rear Suspension
(1) Alternative Shock (OEM NFP), part: 1623311780, £47.47
(2) Flexible Bush, part: 517109 (NFP)
(3) Flexible Bush, part: 517110 (NFP)
(1) Rear Suspension Arm
Left, part: 5175P3 (NFP)
Right, part: 5175Q6 (NFP)
(2) Rear Suspension Rebound, part: 516631 (NFP)
(3) Cup, part: 516721, £14.20
(10) <Already Listed as (9) under Torsion Diagram>
Thermostat
Rear Torsion
Rear Suspension
jakuboz
Yup, probably some misunderstanding- front/rear mounts of the rear suspension, so number 6 and 7 from second diagram.GiveMeABreak wrote: 11 Jul 2024, 10:22 I already provided you with the front suspension parts here on 02/04/2024:
Thank you.
- x 6946
(6) Rear Crossmember Mountings Left, part: 513169 (NFP)
Right, part: 513170, (NFP)
(7) Rear Crossmember Mountings, part: 513171 (NFP)
Althesandie
- x 5
Hi Marc, would it be possible to get the part numbers of the schraeder valves on my AC system please, Vin number is VF7**************[VIN obfuscated, can be read by forum staff] please. Many thanks for any help
