C5 - weird sound
salik1992
C5 - weird sound
Unread post by salik1992 »
Hello everyone,
Recently I have noticed a weird rhythmic metallic sound coming from the rear left corner.
- Car: Citroen C5 Tourer 2017 with 2.0BlueHDI
- It is inaudible from the cabin even with driver's door open
- When standing at the rear, it sounds "distant", only when getting close to the rear-left wheel / exhaust, it is properly audible
- I've never heard it after startup
- It stops with the engine
- I've tried citrobatics and all seems to work fine, rocking the suspension is equal in all corners, switching to sport makes all corners equally harder
- I've checked LDS level on the lowest setting and there was no fluid visible above the grill, but from what I understood that wouldn't be if it was filled properly
- The car was rebuilt by czech citroen service about a year ago after front-left impact in late 2020 but I bought it only last autumn (2023) so I do not know the full history
PaulC5
x 675
Re: C5 - weird sound
Unread post by PaulC5 »
Check all the exhaust clamps/brackets in case one of them has rusted through.
x 1938
Does the speed of the clicking change with engine speed? If yes, is engine speed or half engine speed?
salik1992
PaulC5 wrote: 05 Jul 2024, 12:06 Check all the exhaust clamps/brackets in case one of them has rusted through.
Thanks, for the tip, they all seem fine and the sound is too regular.
Paul-R wrote: 05 Jul 2024, 15:12 Does the speed of the clicking change with engine speed? If yes, is engine speed or half engine speed?
Yes, I had an opportunity to test it. It definitely is connected to engine rpms. If I had to guess I'd say it's 1:1 connection (double rpms result in double frequency of the clicking) but I'm not 100% sure with this as the increased engine volume nearly drowns the clicking completely at that point.
x 1938
I don't have any idea at the moment but maybe using an engine stethoscope will help to narrow down where the noise is coming from.
https://www.ebay.co.uk/sch/i.html?_from ... =0&_sop=15
