Sloppysod
x 392
Unread post by Sloppysod »
Hi Marc, can you please let me know the part numbers for both cold weather screens for my C5X?
Cheers
[/quote]
Hi Marc,
Further to, just found this image, but no part numbers, do these look right, Items 20, 21 & 22?
Sloppysod wrote: 27 Jun 2024, 13:56 Cheers
Stu
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6956
Yes, but they're not listed for your vehicle Stu - only the EVs... are you sure you want to be blocking the air flow / cooling on a non EV?
Parts specifically state Very Cold Countries and PHEV for these three and they're not listed under your VIN.
(20) Air Inlet Module Sealing, part: YL020444XT, £28.90
(21) Air Inlet Module Sealing Right, part: YL020445XT, £23.09
(22) Air Inlet Module Sealing Left, part: YL020446XT, £23.09
Just want to make that clear that this may cause cooling issues if used here.
Sloppysod
x 392
Thanks Marc, mine is A PHEV so all good to go to my local dealer. Thanks.
Surprised about the VIN?
VR7**************[VIN obfuscated, can be read by forum staff]
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6956
Yes, it's shown on the diagram, but no part listed under your VIN as UK is not designated a cold climate country - so these are intended for places like Norway, Siberia and the like.
perfidus
x 6
Unread post by perfidus »
Citroen Jumper III 2016 (Euro6) - 2.0 BlueHDi motorization (DW10FUC)
Please help me to confirm the part number for high pressure air conditioning pipe connecting the compressor with the condenser unit.
I have this code: 1614010280. Found different codes mentioned as equivalence: 1684874380 or 1379563080.
Those who don't know history are destined to repeat it!
dave101ua
Unread post by dave101ua »
Hello !
Could you please tell me part number for timing belt ?
which parts are usually replaced together with timing belt ? I need those ones too
Thanks in advance !
VIN is : VF7**************[VIN obfuscated, can be read by forum staff]
pugpirate
Unread post by pugpirate »
Hi again,
These will be coming thick and fast now!
Exhaust mid section
Exhaust back box
Wiper arms
Thanks, R
pugpirate
All wheel bearings
All wheel bearing hubs
Thanks again!
Reuben
pugpirate
Coolant level sensor
Reuben
Timmycitroen
Unread post by Timmycitroen »
Hi does anyone have the
Timing belt and water pump kit part numbers for VF7**************[VIN obfuscated, can be read by forum staff]
Thanks in advance
Maybe a manual with torque settings etc too?.
x 6956
perfidus wrote: 05 Jul 2024, 06:49 Citroen Jumper III 2016 (Euro6) - 2.0 BlueHDi motorization (DW10FUC)
(1) Refrigerant Pipe, part: 1640503280, £409.13
Or part: 1640503180, £377.35
So may need to check for correct one with dealer, as 2 types are specified under (1)
(3) Refrigerant Pipe, part: 1684874380, (Can't order - maybe an issue)
(4) Refrigerant Pipe, part: 1634181280, £400.82
x 6956
dave101ua wrote: 05 Jul 2024, 07:08 Hello !
Thanks in advance !
(18) Timing Kit including Coolant Pump and Rollers, part: 1610278280, £356.95
x 6956
Timmycitroen wrote: 05 Jul 2024, 12:21 Hi does anyone have the
Thanks in advance
See direct post above, this is the same part number for the complete kit as your vehicle:
I don't have a procedure for this engine. Suggest you look at Haynes online:
https://haynes.com/en-gb/car-manuals-1
pugpirate
Hey guys sorry to pester. I posted some part number requests on the 5th. Its the exhaust sections that are on the urgent side 🤞🤞!!! Thanks so much, Reuben
x 6956
I've only just picked this up as I've been busy with other matters, but here you are:
NFP = No Longer Available from Peugeot
Exhaust
Rear Silencer
OEM Original, part: 1726AA, £325.46
Cheaper, part: 1607352080, £239.76
Cheaper Option, part: E12840A, £
Intermediate Exhaust
OEM - part: 1717J1 (NFP)
Cheaper alternative, part: E12831Q, £203.40
The others will follow shortly....
Front Hubs / Bearings
(3) Front Wheel Hub, part: 330785, £179.77
(4) (16, D & 5):
OEM part: 335016, £115.80
Cheaper kit, part: 1681934780, £31.69
Rear Bearing / Hub
(1) Rear Swivel Pin Left part: 517618 (NFP)
Right, part: 517619 (NFP)
(2) Rear Hub Bearing:
OEM, part: 374868, £175.15
PSA Cheaper Option, part: 1681929880, £78.18
(3) Hub Bearing Nut, part: 373928, £7.24
(4) Wheel Hub Plug, part: 374045, £6.92
Wiper Arms
(4) Window Wiper Blade Holder Right, part: 6429P9, (NFP)
(5) Window Wiper Blade Holder Left, part: 6429Q0, (NFP)
Coolant Level Sensor
(3) Coolant Level Sensor, part: 130689, £107.41 (yes, this is not a typo! :shock: )
