Angel eyes H1
Wynand
Angel eyes H1
Hi I ave the angel eye headlight on my Citrien C2, using H1 LEDs, for the high and low beam. As per normal the low beams turn off when the high beam is activated, but can you run both together for a better light pattern, or will it damage the "plastic" lenses
Reason: Signature removed
- x 2008
Re: Angel eyes H1
LED's should be safe (less heat than older bulbs)...... but a really BAD pattern due to the "light source" being at a different position to the original bulbs.....thus really bad for on-coming drivers
- x 1061
Re: Angel eyes H1
It would certainly be possible if you used a relay to send power to the dipped beam when the high beam was switched on.
