pugpirate
Unread post by pugpirate »
Hi guys.
Part number for my radiator fan please 🙏🏻.
Reuben
x 6946
pugpirate wrote: 27 Jun 2024, 08:54 Hi guys.
Reuben
Note: NFP = No Longer Available from Peugeot
I'm not sure which specific parts you want, so have listed the individual items.
(1) Engine Fan Shroud, part: 1308V6, £166.28
(2) Engine Fan, part: 1250G0 (NFP)
(9) Cooling Fan Harness, part: 126798 (NFP)
(10) Fan Resistor, part: 1267E3, £54.31
(11) Fan Resistor, part: 1267A9, £53.89
(13) Electric Relay:
35 Amp Black, part: 6547TX, £13.26
45 Blue, part: 6555HL, £44.53
Sloppysod
x 397
Unread post by Sloppysod »
Hi Marc, can you please let me know the part numbers for both cold weather screens for my C5X?
Cheers
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6946
These are only available for PHEV vehicles in very cold countries and are not listed as an accessory.
Sloppysod
x 397
GiveMeABreak wrote: 27 Jun 2024, 13:59 These are only available for PHEV vehicles in very cold countries and are not listed as an accessory.
Thanks, I'm surprised they are not listed - well not really!😒
They are a standard supplied part for Northern European supplied cars. I will have to start digging deeper. - Norway perhaps.🤔
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6946
The parts are shown without a VIN, but as far as I can see it's a different part originally fitted, so you would have to disassemble the grille and bumper sections to remove and refit - so a butcher job. Seems it's only needed for PHEV vehicles though.
x 1941
Could I possibly have the current service schedules for our 308 and X7 please? I'm not sure that the service booklet issued with cars is still accurate.
308 VF3**************[VIN obfuscated, can be read by forum staff]
X7 VF7**************[VIN obfuscated, can be read by forum staff]
x 6946
Here you go Paul:
Click to Zoom
X7
308
x 1941
Ta!
Paul73
Unread post by Paul73 »
Hi
Could I ask for the part numbers for the under tray clips please? Our car has clearly been carefully dismantled by the main dealer in the past.....not
VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Successfully changed the oil, oil filter, air filter (disgusting) and pollen filter (even more disgusting). Not quite sure what main dealer care we've been paying for!
x 6946
(70) Bolt, part: 9809840080, £.048
(71) Flanged Nut, part: 693658, £1.67
(72) Removable Rivet, part: 6997T2, £1.21
(73)Rivet, part: 1622749580, £0.23
(74) Threaded Screw with Washer, part: 9674550680, £2.51
(75) Flanged Nut, part: 450343, £2.27
(76) Insert Clip, part: 7568NZ, £0.31
(77) Bolt, part: 9840945580, £0.48p
508c5
x 4
Unread post by 508c5 »
Hello,
Can you pls. provide the OE part number for the throttle body of a Peugeot 3008 1.6L 2015 165bhp with vin number VF3**************[VIN obfuscated, can be read by forum staff] ?
thx
Paul73
GiveMeABreak wrote: 30 Jun 2024, 13:17 Image
Many thanks for this. Is there anything that shows the detail of the fixing where part (1) meets the OSF wheel arch liner? Dealer has kindly ripped that mounting through
thanks again!
x 6946
@Paul1973: This is the front wing diagram, so any bits you need, let me know:
x 6946
508c5 wrote: 30 Jun 2024, 13:44 Hello,
thx
(5) Air Intake Throttle Valve Housing, part: V867527880, £457.22
