x 1485
1109AL is the right one.
Yours apparently does have a balancer unit in the sump.
Paul73
Unread post by Paul73 »
RichardW wrote: 24 Jun 2024, 12:54 1109AL is the right one.
many thanks!
x 6956
Re: Bleeding coolant on 2015 2.0 150hp C4 grand Picasso mk2
Timmycitroen wrote: 24 Jun 2024, 12:35 Would you know what part. Numbers are for offside lower rear arm
And Nearside one or have a schematic or drawing of the parts in this area ,
Was wondering wether I can replace bushes or just change whole bit
Let me know what items you need part numbers for.
Timmycitroen
Unread post by Timmycitroen »
5, 6 7 ,8 and 9. Please
Thank you
I would guess there would be a rebuild kit for all these bits
Looks a bit of a bind to change
x 6956
(1) Rear Suspension Crossmember, part: 1647872280, £1113.65 *
(5) Rear Crossmember Mountings. part: 9803481180, £51.44
(6) Rear Crossmember Screw, part: 9672888080, £4.99
(7) Plug, part: 698858, £2.34
(8) Rear Arm Vibration Damper, part: 9673496880 (No Longer Available), £174.07
(9) Buffer, part: 9804015980, £45.37
* I've included part (1), which includes 'A' & (5). I suspect that the item (8) which is no longer available separately may be part of the whole assembly, but the dealer should be able to confirm.
Old Nick
x 3
Unread post by Old Nick »
Hello,
My 2011 C5 had typical brake leak pedal movement and was leaking brake fluid on the underside, just about the middle of the car, so I presume it is the brake line towards the rear. VIN VF7**************[VIN obfuscated, can be read by forum staff]. Could you help me with (a) part number(-s) for the line(-s), please.
Kind regards, Nils S
x 1485
Here's the piping diagram with part numbers, if you want to know any prices, let us know. There are separate pipes to each rear wheel from the ABS unit.
Timmycitroen
GiveMeABreak wrote: 24 Jun 2024, 19:40 (1) Rear Suspension Crossmember, part: 1647872280, £1113.65 *
hi do you have a part number for the bushes in the front lower suspension arms
9678311380 Left arm number … I think
9678311280 Right arm number…. I think
There are two one horizontal and one vertical
Was trying just to replace them and not whole arm assembly
Thanks in advance you are a star as I’m struggling to understand what’s needed with an extremely unhelpful Mot tester
Who want £700 for doing this
Old Nick
x 3
RichardW wrote: 25 Jun 2024, 07:54 Here's the piping diagram with part numbers, if you want to know any prices, let us know. There are separate pipes to each rear wheel from the ABS unit.
Good morning. Thank you very much!
No prices required, I live in Norway. Thanks for a great forum.
Kind regards,
Nils S
chris_reade
Unread post by chris_reade »
Morning. Could you possibly give me part numbers for the 2 small pipes coming from the coolant expansion tank on a 2008 C5 X7 2.7 hdi? Degassing pipes I think they are. Many thanks, Chris
x 1485
Timmycitroen wrote: 25 Jun 2024, 08:03
Part No's you quoted are the originals, both have been superseeded. Here's the diagram, the front bush is not shown separately on the diagram - and your VIN does not list the rear bush separately (this only seems to be available for arms that 5mm steel):
Prices for the arms
At those prices not worth faffing with the bushes for a garage. Quite why they are not the same price left / right is anyone's guess!!
x 1485
chris_reade wrote: 25 Jun 2024, 08:23 Morning. Could you possibly give me part numbers for the 2 small pipes coming from the coolant expansion tank on a 2008 C5 X7 2.7 hdi? Degassing pipes I think they are. Many thanks, Chris
Need the VIN to confirm 100%, but these are most likely them, items 17 and 20?
17 is £22.99 and 20 £15.00 - both still showing as available.
chris_reade
Fantastic, Richard. Thanks very much for swift reply.
Campeador
Unread post by Campeador »
Hi everyone,
I hope you're all doing well. I'm planning to change all LHM return lines to my Citroen Xantia 2.0 HDi (1999) since it has been developing several leaks over these months, which I have been "patching" to the best of my abilities. Unfortunately, I can no longer fix the car in my driveway since I've moved and I don't think the neighbours will appreciate me spilling green blood on the community driveway, so I'll be taking it to a shop. They have agreed on doing the manual labor provided I get the parts, since they can not source them through their usual suppliers.
I know there's a Turkish website (Dr. Xantia Car Parts, don't know if I'm allowed to link external sites :? ) which sells "new" return line kits (part no. 5270 AW). Has anyone purchased them, and if so, what's your experience with quality? Must I buy additional parts or tubing in addition to that one to replace any other sections of the return line system? Basically I would like to forget about LHM spills for another set of years if possible.
I'm open to your guidance and other vendors that you find trustworthy (and ship to Spain!).
As usual, here's the VIN number for reference or if part numbers are needed.
Thank you for your time!
Reason: Moved to Parts Thread
x 6956
I've moved your post to the parts thread.
You didn't say front or rear return pipes, so here are both diagrams.
Note: NFP = No Longer Available From Citroen
Rear Return Lines
(1) Oil Return Pipe, part: 5270PA (NFP)
(2) Oil Return Pipe, part: 5270CT (NFP)
(3) Oil Return Pipe, part: 96113926, £19.70
(4) Oil Return Pipe, part: 527070, £12.98
(5) Oil Return Pipe, part: 527071 (NFP)
(6) Oil Return Pipe, part: 5270CV, £7.82
(7) Oil Return Pipe, part: 5270CR (NFP)
(8) Hydraulic Pipe 3 Way Union, part: 5280E2 (NFP)
(9) Hydraulic Pipe 3 Way Union, part: 528087 (NFP)
(11) Hydraulic Return Tube Sleeve, part: 96995814, £2.68
Front Return Pipes
(1) Hydraulic Fluid Return Harness, part: 5270PT (NFP)
(2) Hydraulic Fluid Return Harness, part: 5270JK (NFP)
(3) Oil Return Pipe, part: 5270PK (NFP)
(4) Oil Return Pipe, part: 5270Y1 (NFP)
(5) Oil Return Pipe, part: 96113942, £57.70
(6) Oil Return Pipe, part: 96113941 (NFP)
(7) Oil Return Pipe, part: 5270V7 (NFP)
(8) Oil Return Pipe, part: 26235229, £16.22
(9) Hydraulic Return Tube Sleeve, part: 5280P5, £10.03
(10) Hydraulic Return Tube Sleeve, part: 96995814, £2.68
(11) 3 Way Union, part: 527014, £17.59
