Xantia aerobics
froggy
(Donor 2026)
x 4
Xantia aerobics
Unread post by froggy »
Hi, my S2 Xantia, just doing a bit of Citroen Aerobics. the back of the car refuses to go from the lowest setting into the middle. it will go from the lowest straight to the highest quite happily. wondering why it doesnt like going from low to middle , only on the back, front is fine. many thanks in advance Terry. :?
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 1459
Re: Xantia aerobics
Unread post by xantia_v6 »
Probably the plastic "dog bone" has come off the rear height corrector, maybe the linkage is also seized.
froggy
(Donor 2026)
x 4
Re: Xantia aerobics
cheers
Terry
x 1996
Re: Xantia aerobics
Unread post by Stickyfinger »
IF (not sure from your post) it goes all the way up from low and only goes to "drive" height after being at the "service height" then I would suspect a sticking/dirty/rusting pivot height corrector
froggy
(Donor 2026)
x 4
Re: Xantia aerobics
cheers, thanks.
Terry
