3008 boot not unlocking/opening
DustyBAT
Unread post by DustyBAT »
Hi
I have a 2010 3008, the boot has all of a sudden stopped unlocking therefore I cannot open it. The fob and the interior unlock button doesn't open it. Is there any way I can get it back open? Is there a fuse that may have blown preventing the solenoid from working?
x 1045
Re: 3008 boot not unlocking/opening
Unread post by wheeler »
If you look on the tailgate latch here in the little slot there is a little arm you move with a small screwdriver that will manually release the tailgate latch so you can get it open to do some investigation. First port of call would be to check the wiring where it goes from the body to the tailgate, as this part flexes all the time its a common braking point of the wires.
DustyBAT
Thanks. I had to butcher the catch to get to said lever you mentioned. Managed to get it open. Cannot find any broken wires. Not sure where to look next. Could there be a fuse blown? Sometimes I know some fuses serve multiple applications. Struggling with this and the wife keeps moaning she doesn't have a working boot!
DustyBAT
This is a really strange one. I've tried changing the actuator module and the release button - still nothing! The strange thing Is that the car can still sense the boot is open when I have it open. Also if I lock the car when I am inside and open the boot using the emergency release, the alarm goes off. So strange! I am stumped! :roll:
Djandree
x 38
Unread post by Djandree »
Hello. They got microswitches built in. If the microswitch is broken there is no signal to bsi tell it thet boot is shut. Check with diagbox. Should tell you if its short to earth or if its open. Sometimes loom going from tailgate to car body might be broken
