x 6956
(2) Front Suspension Rest Cup, part: 9817592480, £41.86
(7) Cup, part: 9678749180, £5.64
Narl
x 4
Unread post by Narl »
Hi there.
Would it be possible to get the top mount genuine part number as well please as well as the bolts?
Thanks ??
x 1485
DaveS
Unread post by DaveS »
GiveMeABreak wrote: 16 Jun 2024, 21:58 Front Brakes
(1) OEM Original Brake Disc, part: 1612435180, £151.52 each
Peugeot Cheaper Brake Disc, part: 1687772280, £78.13 each
(3) Brake Pad Kit (A, B, C, D, E & F), part: 1647863980, £201.23
Peugeot Cheaper Set, part: 1639374380, £60.20
Rear Brakes
(1) OEM Non-Ventilated Disc (DIAM 280 EP 16), part: 1673602180, £117.05
Cheaper Peugeot alternative Disc, part: 1686717480, £117.08 (2)
(3) Disc Pad Kit
OEM, part: 1673603480, £124.01
Cheaper Peugeot Alternative Kit, part: 1675989880, £53.38
Parking Brake Bits
If there's anything you want that I haven't provided, let me know:
(3) Secondary Parking Cable, part: 1680794480, £220.76
(4) OEM Secondary Brake Cable, part: 1673595680, £81.68
Peugeot Cheaper cable, part: E074180, £40.00
(12) Secondary Brake Cable Guide, part: 1669575080, £8.56
(13) Handbrake Return Spring, part: 476807, £6.19
(18) Set of 4 Rear Shoes:
OEM, part: 4241N5, £296.04
Cheaper Version, part: 1690924180, £ (Price Unavailable)
(19) Handbrake Mechanism Kit, part: 43108, £120.13
(20) Handbrake Mechanism, part: 434112, £128.71
(21) Handbrake Mechanism Support, part: 433208, £281.77
(22) Brake Shoe Spring Set, part: 430871, £61.52
(23) Brake Shoes Retaining Assembly, part: 430872, £18.56
(24) RR Brake Backplate Fixing Bolt, part: 440610, £2.68
(25) Brake Caliper Fixing Washer part: 440808, £0.76
(26) Brake Caliper Fixing Screw, part: 440542, £7.07
Could you please include item 17 from the parking brake bits(backing plate/splash guard). Could you also grab the PN for a rear wheel bearing if you would be so kind.
Many thanks!
x 6956
(17) Brake Plate
Left: 4211C4, £140.28
Right: 4212C4, £140.28
(2) Rear Bearing Hub
OEM Original, part: 1606374780, £190.92
Cheaper Peugeot Alternative, part: 1681930880, £170.03
(3) Screw, part: 518121, £3.71
(4) Wheel Hub Plug, part: 374047, £14.54
(5) Self-Locking Nit, part: 373927, £42.23
DaveS
Thank you sir!
Althesandie
x 5
Unread post by Althesandie »
hi Marc. Any chance you can get me the part number for a kit for doing the water pump and timing belt on my Picasso vin number VF7**************[VIN obfuscated, can be read by forum staff]. If they don't do a kit can you let me know the part numbers needed please?
Many Thanks
daviemck2006
x 496
Citroën dispatch gear cables
Unread post by daviemck2006 »
Hi. I wonder if someone could find out which gearbox my van has and what the part number of the gear change cables is. The vin is VF7**************[VIN obfuscated, can be read by forum staff]
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Rb46dk
Unread post by Rb46dk »
Hi. My c3 picasso just failed MOT. VIN VF7**************[VIN obfuscated, can be read by forum staff] There is a structural part with a lot of rust! I live in denmark and here the part is called the "forbro" (front bridge). Can you please provide a part number? Its sooo rusty it cant be welded so it needs replaced.
Thanks again in advance for this fantastic service you provide.
I dont think it is the front bridge but a part that connects the "front bridge" (front subframe???) the the front bumper.
A similar part on the c4 picasso is called the "front subframe extension" maybe its that?
x 6956
Althesandie wrote: 23 Jun 2024, 15:39 hi Marc. Any chance you can get me the part number for a kit for doing the water pump and timing belt on my Picasso vin number VF7**************[VIN obfuscated, can be read by forum staff]. If they don't do a kit can you let me know the part numbers needed please?
Many Thanks
No Problem
(6) OEM Original Distribution Kit (3, 4 & 5), part: 1608747480, £184.19
Cheaper PSA Timing Kit, part: 1635067180. £106.26
Contitech Kit, part: 1689586280, £139.63
(15)OEM Distribution Kit Plus Water Pump, part: 1684448280, £252.07
Cheaper PSA Kit inc. Water Pump, part: 1635067180, £167.53
Contitech Kit inc. Water pump, part: 1689586380, £173.82
x 1485
Edit: Crossed with Marc...!
x 6956
Rb46dk wrote: 23 Jun 2024, 16:53 Hi. My c3 picasso just failed MOT. VIN VF7**************[VIN obfuscated, can be read by forum staff] There is a structural part with a lot of rust! I live in denmark and here the part is called the "forbro" (front bridge). Can you please provide a part number? Its sooo rusty it cant be welded so it needs replaced.
Hi, no problem. I think you may be referring to what they call the Subframe Extensions:
(2) Front Subframe Extension
Right, part: 350880, £115.60
Left, part: 350881, £115.60
(Prices are with UK VAT included at 20%)
x 6956
Re: Citroën dispatch gear cables
daviemck2006 wrote: 23 Jun 2024, 16:09 Hi. I wonder if someone could find out which gearbox my van has and what the part number of the gear change cables is. The vin is VF7**************[VIN obfuscated, can be read by forum staff]
You have a BVM6 (BVM ML6 CL) Davie.
(2) Gear Selection Control Cable
OEM Original part: 2444GP, £318.22
Cheaper Citroen Alternative, part: 1637134280, £114.91
Reason: Moved post to Official Parts Thread
Paul73
Unread post by Paul73 »
Could anyone please confirm the correct part number for the oil filter for our C4 G Space Tourer 2.0 HDI VIN VF7**************[VIN obfuscated, can be read by forum staff]? I can see P1109AL on the service invoices for it but when you start looking up alternatives online there's always "without balancer shaft" mentioned. I dont think our engine has a balancer shaft (comes up as a DW10FCC)
thanks!
Timmycitroen
Re: Bleeding coolant on 2015 2.0 150hp C4 grand Picasso mk2
Unread post by Timmycitroen »
Would you know what part. Numbers are for offside lower rear arm
And Nearside one or have a schematic or drawing of the parts in this area ,
Was wondering wether I can replace bushes or just change whole bit
